Results 1 to 8 of 8
    Junior Member
    MEP 2011
    Jun 2012
    12
    Default Showing vertical pipes in floor plan
    Hi all,
    Very noob question but on a floorplan, how would you represent pipes coming down vertically?
    I am drawing out our air compressor and trying to show the drops for the piping on the manufacturing lines in a seperate room.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    Top image = Pipe Down. Bottom image = Pipe Up.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    In fact, here's a general piping DWG I have. Explains a lot. Enjoy.
    PS: AutoCAD MEP automatically does this for you if you are using AEC Objects.
    Junior Member
    MEP 2011
    Jun 2012
    12
    Another quick noob question: what is AEC?
    Here is a picture of what I did, I used ducts for just about everything but I want to do it over and right this time around. On the blue region (the trench) I want to show that as the pipe crosses it, it comes down vertically, I did this somewhat by trying to make it look orthogonal.
  5. #5
    Junior Member
    MEP 2011
    Jun 2012
    12
    *The red pipe that slopes a bit above the blue trench from the second tank behind the wall
  6. #6
    Junior Member
    MEP 2011
    Jun 2012
    12
    Also, for some reason I can't open up the file Styk, I'm going to try again on my main computer.
  7. #7
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    Ah, so you are in fact using AEC Objects. Anything that is considered an "AutoCAD MEP specific object" is an AEC Object. What you'll want to do is start focusing on changing the Display Representation to a single line View.
  8. #8
    Junior Member
    MEP 2011
    Jun 2012
    12
    Just got able to open your drawing, this makes a lot more sense, So I should draw this in schematic mode?
    I started initially with just lines but the maintenance manager said nobody aside from him would understand it, since it was to be presented to finance.
  1. AutoCAD2005 floor plan
    By Dodi El Mahallawy in forum AutoCAD Beginners' Area
    Last Post: 10th Aug 2009, 10:19 pm
  2. floor plan
    By eugene233 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Apr 2009, 12:49 pm
  3. From floor plan to elevation
    By nathan008 in forum AutoCAD General
    Last Post: 24th Oct 2007, 11:27 am
  4. Drawing a floor plan
    By Natjeff in forum AutoCAD Beginners' Area
    Last Post: 14th Jul 2006, 07:30 pm
  5. floor plan layering
    By stabiloboss in forum AutoCAD General
    Last Post: 19th May 2004, 10:10 pm
