+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Forum Newbie
    Using
    AutoCAD 2006
    Join Date
    Jul 2012
    Posts
    2
    Default If I remove Fusion Inventor does it effect my autocad 2012?
    Hi,
    I have recently put Auto Cad 2012 on my laptop, but seems to be very slow. While doing this fusion inventor also downloaded.I was wondering could I remove Inventor as I don't use it, without that effecting my auto cad program? All I do is just basic 2D drawings on autocad and need to speed it up. Could I also remove Autodesk 2012 libary?
    Thank you
  2. #2
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,906
    Default
    Uninstalling Fusion should have no effect on AutoCAD.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  3. #3
    Forum Newbie
    Using
    AutoCAD 2006
    Join Date
    Jul 2012
    Posts
    2
    Default
    Hi JD,
    Thank you for getting back to me.
    I will go ahead and remove Fusion Inventor, anything to speed up my computer. I have another 3D program - solidwords, so that will do me fine. As I stated in the last thread, all I want the autocad is just for basic 2D drawing, and to quicken it up could I also remove such things as Autodesk Material Libary, Autodesk Content Service and simply just leave Autodesk 2012, without effecting the Autocad?
    Thanks very much for time,
    Regards,
    Niall
  4. #4
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,906
    Default
    I don't understand how removing one program will speed up another program, unless the problem is that your hard drive is nearly full.
    When was the last time you ran scandisk and defrag?
Similar Threads
  1. Replies: 0
    Last Post: 9th Aug 2011, 06:10 pm
  2. Looking for feedback on AutoCAD 2012 and Inventor Fusion 2012
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 8th Aug 2011, 10:30 pm
  3. Autodesk Inventor Fusion 2012 Tutorials Required Please
    By glynowen81 in forum Autodesk Inventor
    Last Post: 8th Apr 2011, 07:53 pm
  4. "inventor" Fusion will be shipping for free with autocad.
    By CADkitt in forum AutoCAD General
    Last Post: 1st Dec 2010, 02:19 pm
  5. Inventor Fusion is here.
    By Lazer in forum Autodesk Inventor
    Last Post: 14th Jul 2009, 07:48 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
