+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Forum Newbie
    Using
    Inventor 2012
    Join Date
    Jul 2012
    Posts
    2
    Default how to (curve chamfer?) a curved surface
    hi i am new to this website so bear with me. Im trying to chamfer an edge of a solid piece that has one face flat and the other face curved. but i want the chamfer surface to be curved going along with the original curved surface. I tried both the chamfer and the draft tool but i am not getting the outcome that i would like.
    basically i would like the attached piece chamfered and when i look at it from both the front and right side view, the edge of the chamfers should both be a straight line going down.
    I would really appreciate some help. Let me know if i wasnt specific enough.
    Chair Back.ipt
  2. #2
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,906
    Default
    Sketch1 is not constrained - read this - http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    I do not see a chamfer in the file you attached or a description of what is wrong with it (works fine for me).
    I am pretty sure it is possible to create the design in Inventor
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  3. #3
    Forum Newbie
    Using
    Inventor 2012
    Join Date
    Jul 2012
    Posts
    2
    Default
    gaming chair.jpgChair Back.ipt
    I tried the chamfer but i am not getting the results that i would like. Basically i'm trying to create the side part of the back of the chair in the picture.
    My ideal outcome of this piece is to be able to see two straight edges on both the front and the right side view when chamfered.
    Thx in advance JD.
  4. #4
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,906
    Default
    How much training in Inventor have you had?
    This looks to be too complicated for a beginner.
    If this is a school project - I would start with something easier.
Similar Threads
  1. Make a curved surface a flat surface.
    By AWW in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Oct 2011, 05:32 pm
  2. need to create a flat surface on curved surface
    By harley558 in forum Autodesk Inventor
    Last Post: 23rd Mar 2010, 05:28 pm
  3. curved surface
    By alijahed in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Jul 2009, 05:43 am
  4. Help with curved surface.......
    By sicknote in forum Autodesk Inventor
    Last Post: 27th Apr 2009, 02:29 pm
  5. 3d curved surface
    By mfranke in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Jul 2008, 04:20 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
