Welcome to the forum.
FILEDIA = 1![]()
I was in the process of dimensioning a drawing this morning when I noticed that the tile menu from "leader" has disappeared.
This is the one which appears when you follow the command through to the add text part, hitting return usually prompts a menu to appear with the following options " MText, Teolerance, Block, None etc" only this time the menu is no longer there and the prompts are in the command line.
It's also disappeared from other commands such as "UCS, Face", in this instance it would normally appear stating "Accept, Xflip, Yflip etc".
Any ideas on how to get it back?
FILEDIA = 1![]()
Volume and repetition do not validate opinions forged in the absence of thought.
Thanks, first thing I tried; it's already set to 1.
Have you tried switching workspace? It disappears from toolbar and menu, but you can activate it from command line, am I correct?
Are you the only one who use that computer, or somebody else might change the workspace?
I'm the only one that uses the PC and it makes no difference switching layouts.
Edit : got it working now... " Dynmode " was switched to <-3> for some reason.
Nice work, figuring that one out.![]()
