Page 11 of 11 FirstFirst ... 9 10 11
Results 101 to 105 of 105
  1. #101
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    _solidedit>faces>move faces
  2. #102
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Quote Originally Posted by stef_r View Post
    I also want to shorten my bracket by 2mm...
    ..Is this easy to do or not???
    Yeah, Move > Faces as mentioned above, or you can just CTRL-Click on the face (Subobject Selection) and use the grip.
    http://www.screencast.com/t/rgI241t2t7
    (I couldn't help taking a little jab at Viewbase as I'm using 2011 at the moment )
  3. #103
    Junior Member
    AutoCAD 2011
    Jul 2012
    16
    Default Thanks
    I am very eager to learn about the topics. It is quiet identical and effective may be. Need special attention.
  4. #104
    Full Member stef_r's Avatar
    stef_r's Computer Details
    Windows xp / 7
    DELL
    Electro/Mech
    stef_r's Discipline Details
    Production and repair engineer
    Electro/Mech
    I work as a production and repair engineer at a Dutch company. We do a lot of work for government and other companies as well. My job is to instruct people about the fabrication and modification products to customer standards and handling the incoming repairs. Product are most lightbars (blue and
    Mechanical 2012
    Jul 2012
    The Netherlands
    46
    Quote Originally Posted by nestly View Post
    And it seems SO easy... And it properbly is too.
    I will look into it later this morning but thank you very much for all of your great video's!!!
  5. #105
    AutoCAD 2013
    Nov 2011
    6,056
    You can find the SUBOBJECT SELECTION options in your right click shortcuts menu.
    If you select FACE, then hold down your CTRL key while clicking inside the face you want to move the grip will appear.
    You can release the CTRL key once it appears, click on it, then move it however far you want, either by dragging it
    or by direct distance entry.
    I had never used that myself, and I like it much more than using the SOLID EDITING toolbar.
    You can also do it with PRESSPULL, which is probably easier still.
  1. Brand newby, already made one mistake posting, I need help with lost layout dwg.
    By shifterlg in forum AutoCAD Drawing Management & Output
    Last Post: 10th Mar 2012, 06:01 am
  2. newby in need of some help
    By trell in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Nov 2011, 11:53 am
  3. A few questions to get me started please.
    By grs in forum Autodesk Inventor
    Last Post: 30th May 2009, 07:15 pm
  4. Help me get started on MEP please.
    By cadgal in forum MEP
    Last Post: 8th May 2009, 08:11 pm
  5. Let's get started!
    By hana78 in forum AutoCAD Beginners' Area
    Last Post: 12th Feb 2007, 10:16 am
Tags for this Thread
