Page 2 of 11 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 105
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    No, I did not include a bend. It was strictly a hack job.
    Is this what you were referring to?
  2. #12
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Yes, that is what I was referring to, but it looks like the bend radii are incorrect (hard to tell from picture), it looks like the material is thicker at bend. (see end, or particularly at the punched hole) Could be optical illusion. I answer a lot of sheet metal questions where this is a common mistake - thus I must give you a hard time about it....
  3. #13
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    FjÀrdhundra, Sweden
    5,148
    Since the OP asked about how to draw lines at the start, I don't think the correct radii to get the piece made is the top of his worries...
    MTJIGSTRING = BAZINGA
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    I fully admit to the fact that what I did, as far as anyone with any real knowledge of sheetmetal fabrication goes, was entirely a hack job and should not be mistaken for the definitive method of modeling the bracket. The model was strictly for demonstration purposes only. No offense to those of you with the knowledge I lack and no offense taken on my part. I would like to learn more about sheetmetal fabrication techniques and the proper way of detailing such but I've got limited time and my current job does not require that particular set of skills. We all good?
  5. #15
    AutoCAD 2013
    Nov 2011
    5,985
    Well as long as you're DRAWING something!
    Make it a cold one.
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    stef_r: A quick bracket created using a profile of the shape and the PRESSPULL command. Holes and slots can be punched through afterwards using the same command.
  7. #17
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Profile does not look uniform thickness.
    The outside radius should be = inside radius + thickness.
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Well it's no rough draft. Perhaps it is the angle. I verified that the profile did indeed exhibit a uniform thickness (.09375). For the posted example the inside radius was .0625 and the outside radius was .15625. And yes, I know, the thickness is probably way too much for sheet metal but once again the purpose of the exercise was to demonstrate a method for modeling a simple bracket using a profile.
    If I had know I was being graded today I would have brought a sharper pencil. LoL
    I need to come up with a disclaimer. Objects shown are in no way representative of the real world. View at your own risk.
  9. #19
    Full Member stef_r's Avatar
    stef_r's Computer Details
    Windows xp / 7
    DELL
    Electro/Mech
    stef_r's Discipline Details
    Production and repair engineer
    Electro/Mech
    I work as a production and repair engineer at a Dutch company. We do a lot of work for government and other companies as well. My job is to instruct people about the fabrication and modification products to customer standards and handling the incoming repairs. Product are most lightbars (blue and
    Mechanical 2012
    Jul 2012
    The Netherlands
    46
    Well, I'm impressed by the information and answers I get from all of you here!
    I have posted onto some other fora but after a few days still no answers.
    So as Tiger mentioned in his first post to me, "you have signed up to the best (*polishes nails on shirt and looks at them*) cad-forum there is" is really true!
    I see I have a lot to learn, from AutoCAD and of the specific details about handling (sheet)metal since I'm from school more a 'electric' person than a 'mechanical' person.
    But if I begin to draw (2D) how do I let AutoCAD know wich view I'm working on, or is this a stupid question?
    I mean like if I draw the side of the bracket, I draw a L shape desing.
    When I then use the construction lines to draw the front view, I think I have to draw everything myself because autoCAD doesn't draw the view itself right?
    BTW, I don't think that modeling in 3D and than convert it to 2D will work for me because my lack of skills.
    And since I have a few other brackets to draw later, I sure want to be a small expert in AutoCAD within a year or so...
    (Or am I to confident about that??? ha ha ha)
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,622
    Drawing in 2D using AutoCAD would be like drawing in 2D on a piece of paper. Do you tell the paper which view you are working on? It's a flat, flat, flat world my friend.
    You are familiar with orthographic projection are you not? You know, creating top, front and side views of an object? Basic drafting skills.
  1. Brand newby, already made one mistake posting, I need help with lost layout dwg.
    By shifterlg in forum AutoCAD Drawing Management & Output
    Last Post: 10th Mar 2012, 06:01 am
  2. newby in need of some help
    By trell in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Nov 2011, 11:53 am
  3. A few questions to get me started please.
    By grs in forum Autodesk Inventor
    Last Post: 30th May 2009, 07:15 pm
  4. Help me get started on MEP please.
    By cadgal in forum MEP
    Last Post: 8th May 2009, 08:11 pm
  5. Let's get started!
    By hana78 in forum AutoCAD Beginners' Area
    Last Post: 12th Feb 2007, 10:16 am
Tags for this Thread
