Have you considered "downgrading" to AutoCAD 2011 or 2012? Initial releases are notoriously buggy, and 2013 is no exception. I have it installed only because curiosity got the better of me, but there are enough "known bugs" that I will not use 2013 to save any of my working drawings. 2013 is a new file format, but you can't just work with older formats natively, they're actually "upgraded" to the new format when the drawing is opened, then "saved down" when the drawing is saved. The this conversion may or may not be related to your problem, but not converting "up" then converting back "down" again would eliminate one potential cause of corruption.
