You said you could convert the .dwg to .swf. So what is the problem?
No, nothing, not even help with it. I correspond with someone from there, but they dont like (this person) to know how and what.
PlanningWiz dont accept dwg; only .swf
I have to give name, tekst, dimension W B H, than Floor, wall and so on, an image of product jpg and than an .swf; that is all.
I put a link of my work, but moderator did not want to post it.. snif..
tought it is open link anyone can see, no pub, i dont understand, but it is so..
So i dont think i can do something else in planningWiz.
*Name:
You have 40 characters left.
Description:
If provided it will be displayed in object's info-box.
*Width: (cm)
*Depth: (cm)
*Height: (cm)
Price:
Product link:
Resize
Check if you want to allow the product to be resized by the users (width and depth).
Mirror toolLayer:
Select a layer on which you want the product to be placed.
*Upload swf icon:
Upload the .swf file for the product.Upload image:
Upload an image for the product (.jpg, .png, .gif). The image will be displayed in the product's info-boxPosition:
SO i think i have to change the DWG to get it correct there DIRECT.
because program FlashDWG (change DWG to swf) allows also no a lot
There i have :
Input File :
Output layout (choice to model, layout 1, layout2)
Output Size : Wide : 1024 px Height : 768 px
Background color (all colors but nowhere no color)
Output type : choice between 256 color, Gray, Black and white
Output file
Thanks if someone can tell me where i have to work
Autocad or Flashdwg ??
The problem is : i dont have an object in planningWiz like others, i have a white sheet with my drawing on it.
If someone wants to place a bike to see how mush place it takes between his sofa and table.. Normally, he has to have a 2D drawing (bird view) of my bike; from the mesures i gave.
For ex : a bike of 156 cm long, 75 cm W he can place where he wants.
NO, with me, when they place a bike, they have of square white sheet of 156 cm long, 75 cm W with a drawing of mij bike, smaal on it.
It depend on his place on the sheet in autocad.
Do you understand ?
I put links so you could immediately see the problem, but i dont understand why moderator did not want it.
If i make a parallelle with photoshop; i want to have a gif i can save without background. (i know how to)
here i would like to save my dwg so when i place it in planningWiz, i have a 2D object but without background and of the size i give the programm; so people can make simulation of their sport room and see wat they can have, what they can buy or not, because not enought place.
It does not sound like planningWiz will directly import your bike as its own separate object but more as an image much like when someone using AutoCAD tries to bring an object saved as a JPG, BMP or PDF into AutoCAD.
I don't think you will be able to do what you want to do with the programs you are using.
Since the bike is already a drawing why not draw the room in AutoCAD as well?
I think you are right.
But i search the whole internet, and i did not find another programm to convert autocad into .swf.
Whole room in autocad, no, because i m newbee and i have no capacity to write a programm.
Dont forget, it is for our clients.
So they will be 100-500 to use it, to design their own room.
Im sure, it must work, because someone did it in planningWiz from the same autocad file; but with which programm than ?
I search and search on internet, french, english.. i dont find any other programms; only programms to convert from PDF to swf.
Than you also have a white sheet with a drawing on it.
GRRRR, i thaught : if there is only one programm to convert .dwg into .swf, than it is perhaps my way to save the .dwg (like in photoshop; if you dont select gif and transparency) you have a background).
Thanks for your answer.
File trial of this DWG to SWF converter here...http://www.autodwg.com/dwg-to-flash/
Here's another one...http://www.swftools.com/tools-detail...ool=5121101888
If you need the capability of one of these conversion programs then maybe it is time to buy one.
The planning wiz is using meters, your drawing is in mm. So use the SCALE command in autocad and scale the objects by 1/1000.
If you have more than one piece of equipment in a drawing then you need to separate them into separate files. Use the wblock command to do this, hopefully it will be self explanatory.
"You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
I think what she is saying is when you save a dwg it has a frame around it she is trying to save a dwg with out the frame so it is just the drawing, if in photoshop you save a picture as a Jpeg it will have a solid back ground that will print unless you save it as a gif then its only what you have drawn with no back ground you can also save it as a PSD it also only saves the drawing with no back ground, how you would save a dwg to get this affect I have no clue if it can be done ?
Yes Sparkyuk that is IT
#ReMark
Sorry, but if you read, the first one you give me, is the one i used. Of course we will buy it if i can use it. But for the moment, it does not do wat i need.
It says : Output Size : Wide : 1024 px Height : 768 px
So i think this program is not good : i will try the second one; thanks.
#rkent
No sorry, read above, planningWiz uses cm, so i put my program also in cm when i read the tuto here on this forum..it did not change anything; but i will try to change scaling. But im sure i will get a white sheet with a bigger drawing, but NOT my drawing alone.
Sparkyuk understood what i need.
One think more : i get several .dwg from our manufacturer; some give white background in PlanninWiz, some a grey sheet with a black sheet on it and everything is blocked. SO the way to save the drawing in autocad is WELL the problem i think.
But i dont find any preference to save my drawing because im to bad in autocad. snif..
Euh ????? #
ReMark
The second link you give is exactely the same program as the first one.
so i come again with the same : i only find ONE program to do that on the whole internet ??? That is hard to believe lol...
But also surely, the reason whi it is so diffivult to help me. There is not a lot of persons who use sush programs as planningWiz and want to put their own drawing in it.
