Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2010
    Jul 2012
    2
    Default 3D Modelling - getting started
    Hi,
    I'm trying to get started in 3d modelling as a home student (using 2101 Student Edition) and have been to the tutorials which prompr me to do the following
    1. Open a new drawing
    2. Select an Acadiso3D template (all OK so far - the 3D grid comes up with the view control cube but no tool bars/ribbons)
    3. Then I am prompted to select 3D modelling from the options box (2D or 3D) at the bottom right of the screen so that I can bring up the 3D ribbon. (but I do not have these buttons and so cannot progress !!!)
    4. I would loke to start using the primitives in the second tutorial but, because I cant get to the ribbon I cant bring them up
    Any help would be gfreatly appreciated
    ThanX
    Harcx
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,135
    Welcome to the forum.
    3D modeling is a lot of fun.
    Try this first CTRL+0 . It sounds like your screen may be CLEANED, which hides everything but the actual drawing from sight.
    I am guessing that you used the APPLICATION button up in the left hand corner to open a template.
    To the right of that you should see 2 or 3 icons and an arrow pointing down.
    The arrow will open a dropdown menu.
    Choose SHOW MENU BAR.
    If you succeed in getting the MENU BAR to display then click on TOOLS, and there you can access the RIBBON, TOOLBARS, PALETTES and lots of other things.
    ALSO choose WORKSPACE to show your workspace dialog box.
    Open your WORKSPACE dialog and select a likely candidate.
    You can also click on the OPTIONS button which displays from the APPLICATION button at the bottom right.
    Go to the PROFILES tab and check and or choose one that sounds promising, then SET CURRENT.
    AutoCAD 2012
    Nov 2011
    3,135
    FYI any template ending with ISO will be a METRIC biased template, and the base unit will be millimeters. Entering a length of 1000 to a line command will create a line which will be 1 meter long.
    Nothing wrong with that, if you work in metric units, like I do.
    But better to get used early to being careful about using an appropriate template for the units of measurement in which you want to work.
    If you work in Imperial (feet and inches?) then DO NOT choose an ISO suffixed template.
    Lots of people get pretty far down the road before they come to understand these simple distinctions, and typically after something has gotten screwed up.
    Forum Newbie
    AutoCAD 2010
    Jul 2012
    2
    Default 3D Modelling - Getting Started
    ThanX Dadgad
    I will try ASAP
    Cheers
    Harcx
  5. #5
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Quote Originally Posted by HARCX View Post
    Hi,
    (using 2101 Student Edition) ... (but I do not have these buttons and so cannot progress !!!)
    ....because I cant get to the ribbon I cant bring them up
    Does 2101 version still use Ribbon? I would have hoped by then we will be using thought control.
    Did this install every look correct?
    Attach screen capture of what you see if previous response doesn't fix the problem.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  1. Getting started?
    By shox in forum AutoCAD Beginners' Area
    Last Post: 11th Sep 2009, 06:37 pm
  2. Help me get started on MEP please.
    By cadgal in forum MEP
    Last Post: 8th May 2009, 08:11 pm
  3. Help please in getting started.
    By Mark111 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Mar 2009, 04:13 pm
  4. GETTING STARTED! - The right course
    By CM1 in forum AutoCAD Beginners' Area
    Last Post: 26th Jul 2007, 06:43 pm
  5. Let's get started!
    By hana78 in forum AutoCAD Beginners' Area
    Last Post: 12th Feb 2007, 10:16 am
