+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    Jul 2012
    Posts
    1
    Default Polyface mesh to Solid with Mesh2Solid plugin
    Hello everybody!
    I am new to the forum here...
    I created something in Rhino and imported it in Autocad as .3ds file but the geometry is not a solid one but a polyface mesh and I cannot edit it with boolean commands, thus I cannot continue editing it...
    I found out that there is this plugin Mesh 2 Solid but it is not free and I cannot find a proper crack anywhere..Could anybody help me please...I cannot find any other way to make mesh solid.....
    Thank you in advance
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,122
    Default
    You are not likely to get any assistance here in obtaining a "proper crack". CADTutor does not condone the use of cracked software.
    Isn't the program shareware? The download is free. It is supposed to be try and buy. So, try it once then decide whether or not you want to buy it.
    Another option:
    "Since version 2010 you can directly convert a "watertight" 3D mesh (polyface mesh) to a 3D solid. To keep the original unsmoothed facets, set the FACETERSMOOTHLEV variable to 0. Use the MESHSMOOTH command to convert the 3D mesh to a MESH object (if necessary) and then make the 3D solid from it using the CONVTOSOLID command (right-click on the mesh and choose "Convert mesh to")."
    Source: the CADforum.
  3. #3
    Super Member Patrick Hughes's Avatar
    Computer Details
    Patrick Hughes's Computer Details
    Operating System:
    Win 2000
    Graphics:
    Quadro fx500
    Monitor:
    2x 1920x1080
    Discipline
    Mechanical
    Patrick Hughes's Discipline Details
    Occupation
    Self unemployed - Machine Design
    Discipline
    Mechanical
    Details
    Machine Design
    Using
    AutoCAD pre 2000
    Join Date
    May 2008
    Location
    Rockford, Illinois
    Posts
    588
    Default
    You might try Inventor Fusion - it's free but it expires next year sometime around April or May - it is a development product. Within it there is a way to thicken (I believe it will handle a mesh), creating a solid body.
    www.cadtempo.com
    Time tracking for AutoCAD, Inventor, Revit and other CAD programs
  4. #4
    Full Member togores's Avatar
    Using
    AutoCAD 2013
    Join Date
    Dec 2012
    Posts
    39
    Default
    Convert your Polyface mesh to surface. Once this is done you can use any of the options to create a solid, depending on its geometry.
  5. #5
    Forum Newbie
    Using
    AutoCAD 2010
    Join Date
    Jan 2013
    Posts
    3
    Default trouble with converting polymesh to solid
    hello
    i have been trying to convert polymesh structure to solid to measure dimensions.
    or please let me if there is any other means to calculate or check or to change dimensions with in polymesh structure.i have triedconvtosolid command even surface commaad didnt work. error: cannot convert selected object.
    please help me out!!
    regards
    Quote Originally Posted by ReMark View Post
    Another option:
  6. #6
    Forum Newbie
    Using
    AutoCAD 2010
    Join Date
    Jan 2013
    Posts
    3
    Default
    hello
    i have been tryn to convert polymesh to solid to calculate dimensions or to check. help me out as convtosolid command is not working. or if i can check within polymesh.
    regards
  7. #7
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,122
    Default
    Post a copy of your mesh object in DWG format. Someone here will take a look at it.
  8. #8
    Forum Newbie
    Using
    AutoCAD 2010
    Join Date
    Jan 2013
    Posts
    3
    Default
    I APOLOGIZE, cannot send files as its secured, ill try and ill post solution over here.
  9. #9
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,122
    Default
    So you have a solution or not?
    No one here is going to steal your drawing.
    Is your mesh watertight?
    If you had access to AutoCAD 2012 or higher you could try using the SURFSCULPT command.
    "The SURFSCULPT command automatically combines and trims a collection of surfaces that enclose a watertight area to create a solid."
Similar Threads
  1. Polyface Mesh to Solid
    By joefromjersey in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Aug 2012, 07:35 pm
  2. How to Convert Polyface Mesh to Solid?
    By Kion_w in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Dec 2009, 12:53 pm
  3. Polyface Mesh to 3d Solid - lsp???
    By luckysairs in forum AutoCAD Beginners' Area
    Last Post: 7th Oct 2009, 10:38 am
  4. Polyface-Mesh to 3D Solid?
    By Kremer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Jul 2009, 12:17 am
  5. Polyface Mesh v. 3D Solid
    By mcbunn in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Jun 2008, 12:52 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
