Results 1 to 5 of 5
    Full Member
    AutoCAD 2006
    Jul 2008
    96
    Default _DIMJOGLINE Unknown command "DIMJOGLINE".
    Hello there, I need help from you guys.
    I am using autocad 2006 and 2008 in our office, but the autocad 2008 is limited licence only and its very slow. I am tried to copy the macro of the DIMJOGLINE (^C^C_DIMJOGLINE) from the autocad 2008 and I thought it will work. I also add a toolbar of the dimjogline. Any advice my friends? Any possible way to use the dimjogline command in autocad 2006? Thanks
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    I'm afraid that you will not be able to use that command in version 2006 - seems that was introduced in version 2008. The button macro you copied is just calling for a built-in command, so if the command isn’t available in your version cannot help at all. A workaround will be to find an AutoLISP routine that match the said functionality.
    By the way, what do you mean by "limited license"?
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Full Member
    AutoCAD 2006
    Jul 2008
    96
    Default Thanks
    Hi Msasu,
    thanks very much for the quick reply
    yes, we have a limited license only for autocad 2008, not all the computers installed the autocad 2008. Few of them only. I hope someone here will donate a lisp. Thanks Msasu
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    So, that "limited" statement is like in "limited number of licenses" and not like in "limited features/functionality"?
    Regards,
    Mircea
  5. #5
    Full Member
    AutoCAD 2006
    Jul 2008
    96
    You are correct Msasu we have only limited number of licenses only. Thanks
  1. Unknown command "_check". Press F1 for help.
    By ahyin in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Dec 2011, 08:49 am
  2. "Unknown command" echo at comand line
    By sadhu in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Sep 2011, 04:35 pm
  3. "chamfer" unknown command in lisp routine
    By cso in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Apr 2011, 06:49 pm
  4. Unknown command "-BEDIT". Press F1 for help.
    By tutt in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Feb 2011, 03:18 pm
  5. Open and Save command causes "Unknown Command" error
    By andythoms in forum AutoCAD General
    Last Post: 12th Nov 2010, 05:00 pm
