Lisp NEEDED: Place Node at center of Circles
Jadeous
Hello. It's been awhile since I've been on here. Missed you guys. :)
I need to ask if anyone has or can write me a Lisp routine that will place a node at the center of multiple (100+) circles in a drawing. I need something 2D. Elevation in 3D is not an issue.
Sounds simple enough, but my guys here at work are stumped.
Any help would be great!
Running:
AutoCad 2012 and AutoCad MEP 2012
Windows 7 Proffesional 64-bit
Rescued from a previous thread and adjusted a little:
;Add Points to Circles (11-VII-2012)
(defun c:APC( / ssetCircles countCircles itemCircle assocCircle assocPoint  )
(if (setq ssetCircles (ssget "_X" '((0 . "CIRCLE"))))
 (repeat (setq countCircles (sslength ssetCircles))
  (setq itemCircle (ssname ssetCircles 0)
        assocCircle (entget itemCircle)
        assocPoint  '((0 . "POINT")))
  (foreach codeDXF '(10 8 410 210)
   (setq assocPoint (append assocPoint (list (assoc codeDXF assocCircle))))
  (if (assoc 62 assocCircle)
   (setq assocPoint (append assocPoint (list (assoc 62 assocCircle)))))
  (if (assoc 6 assocCircle)
   (setq assocPoint (append assocPoint (list (assoc 6 assocCircle))))) ;???
  (entmakex assocPoint)
  (ssdel itemCircle ssetCircles)
(prompt (strcat "\nReplaced " (itoa countCircles) " circles."))
maybe ....
(defun c:Test (/ ss)
 (if (setq ss (ssget "_x" '((0 . "CIRCLE"))))
   ((lambda (i / sn e)
      (while (setq sn (ssname ss (setq i (1+ i))))
         (entmakex (list '(0 . "POINT") (assoc 10 (setq e (entget sn)))(assoc 8 e)))))
     -1
The "APC" one is very close.
The situation I am using this command for is when I Xref in a drawing with circles to represent piping stands. I need to place a Node in the current drawing inside center of the circles and then detach the Xref. So replacing the circles is not nessesary.
Maybe having a Lisp that looks for the centers, not specifically circles.
The following should work for Blocks / Dynamic Blocks / XRefs, with any orientation, scale or rotation:
[color=GREEN];; Points at Circle Centres within Block  -  Lee Mac[/color]
[color=GREEN];; Prompts for selection of a block and creates points in modelspace[/color]
[color=GREEN];; at the centre of every circle in the selected block[/color]
([color=BLUE]defun[/color] c:ptcirblk ( [color=BLUE]/[/color] bd en ml )
   ([color=BLUE]while[/color]
       ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'errno 0) ([color=BLUE]setq[/color] en ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect Block: "[/color])))
           ([color=BLUE]cond[/color]
               (   ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color])
               (   ([color=BLUE]=[/color] 'ename ([color=BLUE]type[/color] en))
                   ([color=BLUE]if[/color] ([color=BLUE]/=[/color] [color=MAROON]"INSERT"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] en))))
                       ([color=BLUE]princ[/color] [color=MAROON]"\nSelected Object is not a Block."[/color])
   ([color=BLUE]if[/color] en
           ([color=BLUE]setq[/color] bd ([color=BLUE]tblobjname[/color] [color=MAROON]"BLOCK"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 ([color=BLUE]entget[/color] en))))
                 ml (RefGeom en)
           ([color=BLUE]while[/color] ([color=BLUE]setq[/color] bd ([color=BLUE]entnext[/color] bd))
               ([color=BLUE]if[/color] ([color=BLUE]=[/color] [color=MAROON]"CIRCLE"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] bd))))
                   ([color=BLUE]entmake[/color]
                       ([color=BLUE]list[/color]
                          '(0 . [color=MAROON]"POINT"[/color])
                           ([color=BLUE]cons[/color] 10 ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] (mxv ([color=BLUE]car[/color] ml) ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 ([color=BLUE]entget[/color] bd)))) ([color=BLUE]cadr[/color] ml)))
   ([color=BLUE]princ[/color])
[color=GREEN];; RefGeom (gile)[/color]
[color=GREEN];; Returns a list which first item is a 3x3 transformation matrix (rotation,[/color]
[color=GREEN];; scales, normal) and second item the object insertion point in its parent[/color]
[color=GREEN];; (xref, block or space)[/color]
[color=GREEN];;[/color]
[color=GREEN];; Argument : an ename[/color]
([color=BLUE]defun[/color] RefGeom ( ename [color=BLUE]/[/color] elst ang norm mat )
   ([color=BLUE]setq[/color] elst ([color=BLUE]entget[/color] ename)
         ang  ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 50 elst))
         norm ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 210 elst))
       ([color=BLUE]setq[/color] mat
           (mxm
               ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( v ) ([color=BLUE]trans[/color] v 0 norm [color=BLUE]t[/color]))
                       (1.0 0.0 0.0)
                       (0.0 1.0 0.0)
                       (0.0 0.0 1.0)
               (mxm
                       ([color=BLUE]list[/color] ([color=BLUE]cos[/color] ang) ([color=BLUE]-[/color] ([color=BLUE]sin[/color] ang)) 0.0)
                       ([color=BLUE]list[/color] ([color=BLUE]sin[/color] ang) ([color=BLUE]cos[/color] ang)     0.0)
                      '(0.0 0.0 1.0)
                       ([color=BLUE]list[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 41 elst)) 0.0 0.0)
                       ([color=BLUE]list[/color] 0.0 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 42 elst)) 0.0)
                       ([color=BLUE]list[/color] 0.0 0.0 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 43 elst)))
       ([color=BLUE]mapcar[/color] '[color=BLUE]-[/color] ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 elst)) norm 0)
           (mxv mat ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 ([color=BLUE]tblsearch[/color] [color=MAROON]"BLOCK"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 elst))))))
[color=GREEN];; Matrix Transpose  -  Doug Wilson[/color]
[color=GREEN];; Args: m - nxn matrix[/color]
([color=BLUE]defun[/color] trp ( m )
   ([color=BLUE]apply[/color] '[color=BLUE]mapcar[/color] ([color=BLUE]cons[/color] '[color=BLUE]list[/color] m))
[color=GREEN];; Matrix x Vector  -  Vladimir Nesterovsky[/color]
[color=GREEN];; Args: m - nxn matrix, v - vector in R^n[/color]
([color=BLUE]defun[/color] mxv ( m v )
   ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( r ) ([color=BLUE]apply[/color] '[color=BLUE]+[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]*[/color] r v))) m)
[color=GREEN];; Matrix x Matrix  -  Vladimir Nesterovsky[/color]
[color=GREEN];; Args: m,n - nxn matrices[/color]
([color=BLUE]defun[/color] mxm ( m n )
   (([color=BLUE]lambda[/color] ( a ) ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( r ) (mxv a r)) m)) (trp n))
If it helps, I am working with TSI stands. Each stand has a circle around it for the "clearance area".
If I explode the Stand, the circle disappears and the rest of the stand becomes 3d faces.
So maybe that is why the lisp from Lee Mac isn't working on the drawing. The TSI items are not considered blocks.
If I can find a way to extract that circle from the TSI stand, I can use the first lisp on this thread or find a lisp that will recognize the circle in the item.
My apologizes.
I did not realize how specific the dteails would need to be.
It is truely amazing how simple concepts require such detailed solutions.
They are a Cadduct item.
TSI is the company that sells the software and they also know that when are in need of this lisp tool, but they want more money to give it to us.
So I was hoping to find a work-around for the time being.
I figured if I could find a lisp that places a node at the centers of an xref'd Cadduct item, I would cool for now.
I loaded the Lisp and ran the EE command.
This is what came up in the command bar:
Command: ee
Select object:
(-1 . )
(0 . "MAPS_SOLID")
(330 . )
(5 . "21BE")
(100 . "AcDbEntity")
(67 . 0)
(410 . "Model")
(8 . "MP-HNGR")
(8 . "MP-HNGR")
(300 . "3-1/2")
(300 . "Celgene: 2nd Floor (+15'-0\")")
(300 . "Pipework: Carbon Steel")
(300 . "Carbon Steel x 0.0")
(300 . "4")
(300 . "7")
(300 . "0 (inch)")
(300 . "0")
(300 . "0")
(300 . "")
(300 . "ASJ x 1.5")
Command:
Nothing happened after that.
  • 2 years later...
                 ml (RefGeom en)
           (mxm
                       (1.0 0.0 0.0)
                       (0.0 1.0 0.0)
                       (0.0 0.0 1.0)
               (mxm
                      '(0.0 0.0 1.0)
Thank you so much!! I just had to calc civil3d points for over 300 penos for a surveyor to set out. You just saved me over 2 hours work. I think I owe you a beer!
Thanks Dan! - I'm delighted that you found the program so useful and that it has saved you so much time!
Cheers,
Lee
  • 3 years later...
                 ml (RefGeom en)
           (mxm
                       (1.0 0.0 0.0)
                       (0.0 1.0 0.0)
                       (0.0 0.0 1.0)
               (mxm
                      '(0.0 0.0 1.0)
Help me, edit to SELECT (by windows) multi Block?
Thanks.
Change the first function to:
(defun c:ptcirblk ( / bn cl en id ml ss )
   (if (setq ss (ssget '((0 . "INSERT"))))
       (repeat (setq id (sslength ss))
           (setq id (1- id)
                 en (ssname ss id)
                 bn (cdr (assoc 2 (entget en)))
                 ml (refgeom en)
           (foreach pt
               (cond
                   (   (assoc bn cl)
                       (cdr (assoc bn cl))
                   (   (   (lambda ( bd / bl bx )
                               (while (setq bd (entnext bd))
                                   (if (= "CIRCLE" (cdr (assoc 0 (setq bx (entget bd)))))
                                       (setq bl (cons (trans (cdr (assoc 10 bx)) (cdr (assoc 210 bx)) 0) bl))
                               (setq cl (cons (cons bn bl) cl))
                               bl
                           (tblobjname "block" bn)
               (entmake
                   (list
                      '(0 . "POINT")
                       (cons 10 (mapcar '+ (mxv (car ml) pt) (cadr ml)))
