Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Forum Newbie
    AutoCAD 2008
    Jul 2012
    8
    Unhappy Help to calculate Area!
    I need help to calculate area of multiple closed polyline shapes. In my drawing I could have hundreds of shapes as shown in the picture. I want to find total of the shaded area by adding the area of the outer shapes. Then subtracting the area of the Inner shapes.
    Maybe there is a better way to do it? Any help would be appreciated.
    Thanks.
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,135
    Welcome to the forum.
    Are they all HATCHED with a SOLID HATCH like these seem to be?
    The area of all hatches, or if not all, selected ones, or FILTERED ones could be found.
    AutoCAD 2012
    Nov 2011
    3,135
    When in doubt check LEE MAC out .....
    http://www.lee-mac.com/totallengthandarea.html
    Thanks Lee!
    Forum Newbie
    AutoCAD 2008
    Jul 2012
    8
    Quote Originally Posted by Dadgad View Post
    Dadgad, Thanks for your reply..
    The shapes are not are not hatched... I hatched them only to help illustrate the area that i want calculated..
  5. #5
    AutoCAD 2012
    Nov 2011
    3,135
    Did you click the LEE MAC link, and look at the total area function in that lisp?
  6. #6
    Forum Newbie
    AutoCAD 2008
    Jul 2012
    8
    I am evaluating that routine right now..
  7. #7
    Forum Newbie
    AutoCAD 2008
    Jul 2012
    8
    I tried LEE MAC's routine for total area. This is good, however this takes all the shapes and adds all the areas together. Maybe I'm not thinking about this the right way.
    What I need is the sum of all the outer shapes and then subtract the sum of all the inner shapes. I am going to try to create the routine myself. Its been a while since I've done a custom lisp. I think its just a matter of creating a couple of selection sets, one for the outer shapes and one for the inner shapes. Figuring out the total area for each and then subtracting.
    We'll see how it goes..
  8. #8
    AutoCAD 2012
    Nov 2011
    3,135
    You could very easily use the FILTER command, set it up to only select items you are after, then use the lisp on the selection set, or GROUP them.
  9. #9
    Forum Newbie
    AutoCAD 2008
    Jul 2012
    8
    I appreciate your advice Dadgad.. I will certainly try that.
  10. #10
    AutoCAD 2012
    Nov 2011
    3,135
    If you get the FILTER set up so that you are happy with it, be sure to SAVE AS in the filter dialog box, so that it will be available
    right out of the gate when you need it another time.
    It is a very powerful and useful tool.
    I have about 8 different saved filters which I routinely use, and it is very helpful not having to redefine them each time I want to use them.
    You can also start from one of your saved FILTERS and then add or subtract items, to suit a specific search selection.
  1. calculate surface area
    By dirtlegg in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Apr 2012, 02:29 pm
  2. calculate 3D polyline area
    By bepcec in forum AutoCAD Beginners' Area
    Last Post: 30th Nov 2011, 04:45 pm
  3. calculate the area of a surface?
    By dumfatnhappy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Oct 2009, 08:27 pm
  4. Calculate Area of Hatch
    By cyberdos in forum AutoCAD General
    Last Post: 25th May 2007, 02:42 pm
  5. How do I calculate the area of 3D surfaces
    By Marcela in forum AutoCAD General
    Last Post: 28th Jun 2005, 10:10 am
Tags for this Thread
