tuannmvncc Posted July 12, 2012 Share Posted July 12, 2012 Hi everyone, I've got the problem as you can see in the attachment here. I've got to create a dynamic block for Rebar, with symbols (which are blocks) at two end of the bar line can be changed scale follow annotation scale changes. The problem is after I have stretch the linear grip to change the length of the rebar, if I change to another annotation scale, the sybol block auto jump to the original position, not at the ends of line as I expected. Could you please give me some advice to keep the symbols at ends? Thank you. Anno Block.dwg Quote Link to comment Share on other sites More sharing options...
