incrementing numbers and letters
JPlanera
I made a couple routines for a friend who wanted to increment numbers and letters. I know there are a few different programs out there already but you only learn by trying, right! I used kind of a different approach than the programs I have seen. I tried to understand Lees suite but promptly gave up on that adventure... for now... :?
Please take a look as I would like to know if I did anything that could be improved. All your input lately has been much appreciated, thank you all!
The numbering program creates a new text style and gives the user an option to add a suffix to the number with a default option. Is the key the only way i can exit this to be able to reset my variables?
(defun c:incnum(/ *error oldcmd oldtextstyle num tht inc lr bp)
(setq oldcmd (getvar 'cmdecho)
     oldtextstyle (getvar 'textstyle)
 (defun *error* (msg)
   (if oldcmd (setvar 'cmdecho oldcmd))
   (if oldtextstyle (setvar 'textstyle oldtextstyle))
   (setq msg "Function Completed")
   (princ msg)
 (setvar 'cmdecho 0)
 (command "-style" "ROMANS" "romans.shx" "" "" "" "" "" "")
 (initget 7)
 (setq num (getint "\nEnter number to start:"))
 (initget 7)
 (setq tht (getreal "\nEnter text height desired:"))
 (initget 7)
 (setq inc (getint "\nEnter number to increment by:"))
 (initget "Left Right")
 (setq LR (getkword "\nChoose kerf [Left/Right] <Right>: "))
 (if(not LR)(setq LR "Right"))
 (initget 1)
 (while
  (setq bp (getpoint "\nPick point--Press <Esc> when finished"))
   (entmake
    (list
     (cons 0  "text")
     (cons 1
    (if
      (= LR "Right")
      (strcat(itoa num)",r")
      (itoa num)
     (cons 10  bp)
     (cons 11 bp)
     (cons 40 tht)
     (cons 7 "romans")
 (setq num (+ inc num))
 (initget 1)
The letter program is set up to always display capital letters regardless of the case of the input.. Also it will quit after letter "Z".
(defun c:inclet(/ *error oldcmd start nascii tht bp)
(setq oldcmd (getvar 'cmdecho))
   (princ msg)
 (setvar 'cmdecho 0)
 (initget "a b c d e f g h i j k l m n o p q r s t u z w x y z")
 (setq start (getkword "\Enter starting letter: "))
 (if(> (setq nascii (ascii start)) 90)
    (setq nascii (- nascii 32)))
 (setq tht (getvar "TEXTSIZE"))
 (initget 1)
 (while(<= nascii 90)
  (entmake
   (list
   (cons 0  "text")
   (cons 1 (chr nascii))
   (cons 10  bp)
   (cons 11 bp)
   (cons 40 tht)
  (setq nascii (+ 1 nascii))
  (initget 1)
Consider the following code:
([color=BLUE]defun[/color] c:incnum ( [color=BLUE]/[/color] *error* bp inc lr num tht )
   ([color=BLUE]defun[/color] *error* ( msg )
       ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]member[/color] msg '([color=MAROON]"Function cancelled"[/color] [color=MAROON]"quit / exit abort"[/color])))
           ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nError: "[/color] msg))
       ([color=BLUE]princ[/color])
   ([color=BLUE]if[/color] ([color=BLUE]null[/color] ([color=BLUE]tblsearch[/color] [color=MAROON]"STYLE"[/color] [color=MAROON]"ROMANS"[/color]))
       ([color=BLUE]entmake[/color]
               (0 . [color=MAROON]"STYLE"[/color])
               (100 . [color=MAROON]"AcDbSymbolTableRecord"[/color])
               (100 . [color=MAROON]"AcDbTextStyleTableRecord"[/color])
               (2 . [color=MAROON]"ROMANS"[/color])
               (70 . 0)
               (40 . 0.0)
               (3 . [color=MAROON]"romans.shx"[/color])
   ([color=BLUE]initget[/color] 7)
   ([color=BLUE]setq[/color] num ([color=BLUE]getint[/color] [color=MAROON]"\nEnter number to start: "[/color]))
   ([color=BLUE]setq[/color] tht ([color=BLUE]getreal[/color] [color=MAROON]"\nEnter text height desired: "[/color]))
   ([color=BLUE]setq[/color] inc ([color=BLUE]getint[/color] [color=MAROON]"\nEnter number to increment by: "[/color]))
   ([color=BLUE]initget[/color] [color=MAROON]"Left Right"[/color])
   ([color=BLUE]setq[/color] lr ([color=BLUE]cond[/color] (([color=BLUE]getkword[/color] [color=MAROON]"\nChoose kerf [Left/Right] <Right>: "[/color])) ([color=MAROON]"Right"[/color])))
   ([color=BLUE]while[/color] ([color=BLUE]setq[/color] bp ([color=BLUE]getpoint[/color] [color=MAROON]"\nPick point <Exit>: "[/color]))
           ([color=BLUE]list[/color]
              '(0 . [color=MAROON]"TEXT"[/color])
              '(7 . [color=MAROON]"ROMANS"[/color])
               ([color=BLUE]cons[/color] 01 ([color=BLUE]if[/color] ([color=BLUE]=[/color] [color=MAROON]"Right"[/color] lr) ([color=BLUE]strcat[/color] ([color=BLUE]itoa[/color] num) [color=MAROON]",r"[/color]) ([color=BLUE]itoa[/color] num)))
               ([color=BLUE]cons[/color] 10 ([color=BLUE]trans[/color] bp 1 0))
               ([color=BLUE]cons[/color] 40 tht)
       ([color=BLUE]setq[/color] num ([color=BLUE]+[/color] inc num))
Note that your *error* symbol is mispelled where localised.
Thanks, Lee. So using TABLSEARCH will create the style "ROMANS"? I will have to look into this TABLSEARCH further! I noticed you omitted my INITGET in the while statement... Am I correct in saying that the modified *error* routine will now accept ESC and ENTER, and because no variables have been changed, there really is now reason to restrict the user??
I will try to apply the same logic to the INCLET program to see if I can get it to work!
No, tblsearch is merely checking the Style Table for the existence of a TextStyle with the key 'ROMANS'; if this test fails, the Style is subsequently created using entmake.
No, the *error* function will only be evaluated if the user presses 'Esc', as this forces an error and ceases evaluation of the program. The if expression in the *error* function simply suppresses the error message if the user has pressed Esc to cancel the program.
