Tables are one of the most complex objects, after dimensions,*to create and edit through the APIs that AutoCAD offers.* The appearance of a table is controlled by its*properties and methods, along with the table style that it is assigned.* Tables are made up of individual cells which can contain text, blocks, and formulas along with additional formatting.
In the previous posting, Creating a Table Style with AutoLISP and the ActiveX API, I showed an exmple of how to create a custom table style.
In this article, I show for to create a table and then edit the value of a cell by picking a point within a table cell.
(vl-load-com)
;; Example adds a table to model space that is 5 rows by 3 columns
;; with a row height of 10 units and column width of 30 units
(defun c:AddTable( / acadObj curDoc insPt mSpaceObj tableObj)
*** (setq acadObj (vlax-get-acad-object))
*** (setq curDoc (vla-get-ActiveDocument acadObj))
*** (setq insPt (vlax-3d-point 0 0 0))
*** (setq mSpaceObj (vla-get-ModelSpace curDoc))
*** (setq tableObj (vla-Addtable mSpaceObj insPt 5 3 10 30))
*** (vla-put-StyleName tableObj "MyTableStyle")
;; Example shows how to pick a single table cell on screen and change its value.
;; This example demonstrates the ActiveX properties/methods HitTest,
;; GetCellType, GetText and SetText.
(defun c:SelectTableCell ( / pick vHeight vWidth lwrLeft uprRight vector
**************************************** * SS_TABLES cnt eMax tableObj row col cellValueOrg)
* ;; Ask the user for a point on screen
* (if (/= (setq pick (vlax-3d-point (getpoint "\nSelect Cell to edit: "))) nil)
*** (progn
***** ;; Get the corners of the screen display to build our selection set
***** (setq vHeight (getvar "viewsize"))
***** (setq vWidth (* (/ (nth 0 (getvar "screensize")) (nth 1 (getvar "screensize"))) vHeight))
***** (setq lwrLeft (list (- (nth 0 (getvar "viewctr")) (/ vWidth 2)) (- (nth 1 (getvar "viewctr")) (/ vHeight* 2)) 0))
***** (setq uprRight (list (+ (nth 0 (getvar "viewctr")) (/ vWidth 2)) (+ (nth 1 (getvar "viewctr")) (/ vHeight* 2)) 0))
***** ;; Get the current display orientation
***** (setq vector (vlax-make-safearray vlax-vbDouble '(0 . 2)))
***** (vlax-safearray-fill vector '(1 1 1))
***** (setq vector (vlax-make-variant vector))
***** ;; Select all the table objects visible on screen
***** (if (setq SS_TABLES (ssget "C" lwrleft uprright (list (cons 0 "ACAD_TABLE"))))
******* (progn
********* (setq cnt 0
*************** eMax (sslength SS_TABLES)
********* ;; Step through all the items in the selection set
********* (while (> eMax cnt)
*********** ;; Geta table object from the selection set
*********** (setq tableObj (vlax-ename->vla-object (ssname SS_TABLES cnt)))
*********** ;; Return values for what cell was picked in
*********** (setq row 0
***************** col 0)
********* * ;; Below is also a sample to see if a valid cell is picked
******** ** ;; (vla-select table pick vector vector 5 5 :vlax-false 'row 'col)
*********** ;; Check to see if a valid cell was picked
*********** (if (= (vla-hittest tableObj pick vector 'row 'col) :vlax-true)
************* (progn
************* * ;; Get out of the loop
************* * (setq cnt (1+ eMax))
*************** ;; Check to see what the Cell Type is (Text or Block)
*************** (if (= (vla-GetCellType tableObj row col) acTextCell)
***************** (progn
******************* ;; Let's get the value out
******************* (setq cellValueOrg (vla-GetText tableObj row col))
******************* ;; Change the current value
******************* (vla-SetText tableObj row col "Revised Text")
******************* (vla-Update tableObj)
******************* (alert "Cell text was changed.")
******************* ;; Restore the original value
******************* (vla-SetText tableObj row col cellValueOrg)
******************* (alert "Cell text was changed back to the original value.")
******************* (setq cnt eMax)
*********** (setq cnt (1+ cnt))
*(princ)
Sincerely,
* Lee
More...
HyperPics - Blog by Lee Ambrosius
