SMP Posted July 13, 2012 Share Posted July 13, 2012 Hey there forum. I seem to be having an issue with some mtext with a a particular annotation scale set. everytime i open this .dwg all my 1:5000 mtext paper defined widths are shrinking. I can honestly say i am not doing anything as it just open this way! I have fixed this three times already and it is such a pain. But all my other annotative text scale are fine??? Has anyone else ever seen this happen before? Quote Link to comment Share on other sites More sharing options...
nestly Posted July 13, 2012 Share Posted July 13, 2012 Is it just the defined width, or is the mtext height shrinking as well? Can you post a sample drawing? Quote Link to comment Share on other sites More sharing options...
SMP Posted July 16, 2012 Author Share Posted July 16, 2012 It is the width. The text height is always the same. It is still doing it in the one drawing. ??? I thught it might have had something to do with the dynamic columns so i set the troublesome bits to none, but still seems to be doing it? I may just explode them and then do txt2mtxt. I think that may be simplest soulution. I check the drawing that this one was "born" from and the exaxt same entities are fine in the parent dwg. So i clearly did something in this drawing in error. Not sure what? Quote Link to comment Share on other sites More sharing options...
