Results 1 to 5 of 5
    Forum Newbie ktcollardson's Avatar
    AutoCAD LT 2011
    Jul 2012
    3
    Default Attaching an Xref to my title block
    Hello - I am trying to attach the client details as an xref to my title block. This is how it was done at my previous company, but I did not set that up, so I don't know how it was done.
    The problem is this - when I attach the xref, I cannot see it on my page in paper space. If I zoom out as far as possible, the paper layout becomes a tiny dot on the screen. When I then draw a rectangle far to the right of the paper, I see a blue glyph on my paper, so I know that the drawing is there, but I cannot see it (the drawing is inserting very far to the right).
    I would like to figure out how to insert my xref so that it shows up on my page. I have moved the information in the file to 0,0 and inserted at 0,0, but I keep having the same problem.
    Does this description make sense? Is anyone able to help?
    Thank you!
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    The information you are trying to xref in, is that information in PS or MS? PS objects can't be directly xrefed, they have to be in MS.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
    AutoCAD LT 2011
    Jul 2012
    3
    Hello - Do you mean model space? If so, yes, it is in model space.
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    Quote Originally Posted by ktcollardson View Post
    You answered my question, I did ask about PS but it doesn't matter. So open the file you want to xref, go into MS, and do a zoom extents. Does all the information show on screen ok? What is the distance across the width of the objects on screen? Finally, in each drawing use UNITS command and find the insertion scale, are they set to the same value?
  5. #5
    AutoCAD LT 2011
    Jul 2012
    3
    I just figured it out, but I am not sure how I made it work. In the end, I scaled the xrefed file 300x so that I could be sure to see it. I scaled it down once I found it. I am keeping it where it is now! Thank you for your help, though.
  1. Title Block as Block not Xref (ProjectWise))
    By Wigman in forum CAD Management
    Last Post: 1st Mar 2012, 11:17 am
  2. Title Blocks as an Xref or a Block?
    By chulse in forum CAD Management
    Last Post: 27th Jul 2008, 09:10 pm
  3. Title Block or XRef Issues - please help!
    By TMC2004 in forum AutoCAD Beginners' Area
    Last Post: 23rd Jan 2008, 10:33 pm
  4. Xref Title Block And Notes In Paperspace
    By BIGPLC in forum AutoCAD Beginners' Area
    Last Post: 17th Nov 2007, 05:45 pm
  5. INSERTING AN XREF TITLE BLOCK
    By BRENT in forum AutoCAD Drawing Management & Output
    Last Post: 25th Sep 2003, 07:53 pm
Tags for this Thread
