Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Plane in Cad
    Full Member
    AutoCAD 2012
    May 2012
    66
    Default Plane in Cad
    When an appropriate object snap in CAD doesn't appear (see dwg file attached, the only snap that I got was "Center") in order to draw some construction lines on a curved surface, I am wondering whether we have access to "Plane" in CAD (e.g., Front Plane, right... in the same way we do in solidworks)!
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,401
    I am on 2013, there are 3DOSNAPs, check the icons at the very bottom of the screen for that one. Right click and set the ones you might need.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
    Full Member
    AutoCAD 2012
    May 2012
    66
    Actually both 2d and 3d object snaps are on! I assume because my 3D model is more like a curved surface(see dwg file enclosed), other snaps can't be applied. So I wish I could use the Plane in the same way i do in SW. But honestly, I never tried Plane in CAD! So no clue how that works!
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,006
    Quote Originally Posted by User2012 View Post
    SolidWorks is CAD?
    In AutoCAD - UCS.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Full Member
    AutoCAD 2012
    May 2012
    66
    Quote Originally Posted by JD Mather View Post
    SolidWorks is CAD?
    In AutoCAD - UCS.
    If I got it right, I should drag UCS on the surface that I would like to work on. But still I have a hard time to draw on a curved surface even though the object snap is on ( see the link). Becaz of that, I though that there might be the "Plane" or some other ways to do this in Cad as well!
    http://www.screencast.com/users/CAD_...7-1140e0770ec1
  6. #6
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    755
    AutoCad does not work that way... What is your intent?
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
  7. #7
    Full Member
    AutoCAD 2012
    May 2012
    66
    I just wanna draw a 2d sketch on a curved surface in cad.
  8. #8
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,006
    A plane is a plane is a plane - in SolidWorks or AutoCAD or any CAD program.
    A plane cannot be a curved surface.
    A curved surface is not 2d so you cannot possible have a 2d sketch on a curved surface.
    You can create a plane (UCS in AutoCAD) anywhere you need it to draw a 2d sketch.
    You can project (various ways) 2d sketch to curved surface.
    The command is UCS. (you will need to become very familiar with this command so find the Help reference)
    Just like SolidWorks you might need some pre-existing reference geometry. Once you understand the process it is the same in any CAD program.
    Where are you getting your (erroneous) information?
    What book are you using?
    Attach your file here.
  9. #9
    Full Member
    AutoCAD 2012
    May 2012
    66
    I understand that the plane cannot be a curved surface and a curved surface is not 2d!
    I just thought that I should creatework planes to draw the right sketch on a curved surface and then project it to the surface! But now I realize that I have to use UCS in AutoCad instead. Can I simply drag the UCS icon into the drawing?
    PS- I'm gonna learn more about it for sure!Thanx for the Info.
  10. #10
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,006
    No.
    The UCS is Exactly the same as creating a plane in SolidWorks.
    A plane is defined by 3 points.
    an origin
    x direction
    y direction
    SolidWorks and AutoCAD have different aids to define these 3 points, but once you understand what is happening in the background you should be able to create a plane (UCS) in any desired location. This is perhaps the most confusing part of 3D for beginners, but nail it and you will be much more comfortable working in 3D.
    I recommend that you type UCS Enter
    Hit F1 key
    review each of the options and bring up question here one-by-one on any option of the UCS command that you do not understand.
  1. [Help] I'm finding lisp copy from XZ plane to XY Plane
    By ketxu in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Oct 2011, 10:48 am
  2. Replies: 3
    Last Post: 14th Dec 2010, 10:00 pm
  3. Need help for plane
    By john7911 in forum SolidWorks
    Last Post: 5th Oct 2010, 07:15 pm
  4. XY Plane
    By rednour in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th May 2009, 04:44 pm
  5. Any-plane Arc!
    By fahim108 in forum Tutorials & Tips'n'Tricks
    Last Post: 2nd Aug 2006, 07:24 pm
