Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Forum Newbie
    AutoCAD 2013
    Jul 2012
    5
    Unhappy Measuregeom not working, help!
    Hello all,
    I've only just started using AutoCAD 2013 and enjoying the Measuregeom feature for a few days, when all of a sudden it just stopped working. I've got an urgent deadline and it's making my life very difficult, perhaps it happend to someone else here too? Whenever I try to measure a distance, it asks me to enter an option (distance, radius, angle, area etc.), and when I click Distance, it asks me to specify first and then second point again, and then enter an option again, and so on. I really don't know what has happened, any help would be greatly appreciated!
    best
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,135
    Welcome to the forum.
    Have you checked to see if the current PROFILE which is selected in OPTIONS (enter OPTIONS at the commandline), and found on the
    PROFILES tab, is the one you normally use?
    If not, then select the correct one, and click SET CURRENT.
    Forum Newbie
    AutoCAD 2013
    Jul 2012
    5
    Thanks Dadgad! I've only had it for a while and there is just an 'unnamed profile' available on the list which is also the current one... it must be something else then :-(
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Is the problem that it's not giving you the distance, or that it repeats?
    Personally, I hate MEASUREGEOM because of the repeating feature, and have replaced it with the Classic DISTANCE command (DIST)
  5. #5
    Forum Newbie
    AutoCAD 2013
    Jul 2012
    5
    The former, I can't measure anything at the moment, even resorted to using ruler on the screen, which is silly and far from accurate :-( if there is any other measuring tool how can i set it? just typing 'dist' in command line has the same effect - none whatsoever (that is another prompt to type a command). Strange!
  6. #6
    Super Member
    Intel DG33FB
    4GB DDR2 6400
    ATI Firepro 5800
    AutoCAD 2011
    Sep 2010
    1,895
    Can you post the text from the text window (F2) when you're trying to use MEASUREGEOM or DIST commands
    Code:
    Command: _MEASUREGEOM
    Enter an option [Distance/Radius/Angle/ARea/Volume] <Distance>: _distance
    Specify first point:
    Specify second point or [Multiple points]:
    Distance = 0'-3 43/64",  Angle in XY Plane = 0.00000000,  Angle from XY Plane = 0.00000000
    Delta X = 0'-3 43/64",  Delta Y = 0'-0",   Delta Z = 0'-0"
    Enter an option [Distance/Radius/Angle/ARea/Volume/eXit] <Distance>:
    Specify first point: *Cancel*
  7. #7
    Super Member
    Intel DG33FB
    4GB DDR2 6400
    ATI Firepro 5800
    AutoCAD 2011
    Sep 2010
    1,895
    Also for the interim, instead of a ruler, what about placing a dimension (DIMALIGNED)
  8. #8
    Forum Newbie
    AutoCAD 2013
    Jul 2012
    5
    Wow many thanks, dimaligned is a great improvement indeed :-) also discovered quick dimension just now too, still it would be nice to have the old distance inquiry back! F2 seems to be a screen dimmer on my pc, I don't know where to look for this text...
  9. #9
    AutoCAD 2012
    Nov 2011
    3,135
    It sounds to me like your commandline has collapsed vertically to a single line being visible.
    If so, locate the grip on the top center edge of the visible command line window and stretch your commandline window up, so that you see 3 lines displayed.
    Hopefully it will be as simple as that.
  10. #10
    Forum Newbie
    AutoCAD 2013
    Jul 2012
    5
    hahah yes it's there! thanks so much :-) i used autocad 2009 before and it's a new pc too, if these excuse me ;-) much love!
  1. Measure almost anything with the MEASUREGEOM command
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 29th Feb 2012, 08:10 am
  2. Disabling cursor menu during MeasureGeom command
    By Alex B in forum AutoCAD General
    Last Post: 13th Oct 2010, 07:45 pm
  3. Working with 3D
    By Rhayes in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2007, 05:14 pm
  4. Working in 3d
    By rodallg in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Feb 2006, 06:35 pm
  5. Why isn't this working?
    By Baçon in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th May 2005, 10:17 pm
