+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Forum Newbie
    Using
    AutoCAD LT 2004
    Join Date
    Jul 2012
    Location
    bucks, uk
    Posts
    2
    Default Jagged, or "stepped" appearance of diaginal lines
    Hi, I'm very new, but enjoying finding my way in Autocad LT 2004. I'm using a couple of aftermarket books ("For Dummies" and "Skills For Success - No Experience Required") and cross referencing those v tutorials and other posts on here when I get stuck. Working through the basic set up, drawing and precision strategies - haven't got to layers, dims etc yet
    I've noticed that any diagonal line (i.e, one that's not at 0, 90, 180 or 270 degrees) has a jagged or "stepped" appearance. I've highlighted the worst looking ones in red on the attachment
    I'm guessing I've done something dumb somewhere but, despite backtracking, I haven't been able to sort it. How can I correct this?
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,038
    Default
    There is nothing wrong with your lines. It could have something to do with your monitor's resolution though.
  3. #3
    Super Member Pablo Ferral's Avatar
    Using
    Inventor 2010
    Join Date
    Feb 2005
    Location
    London
    Posts
    571
    Default
    Any diagonal line shown on a computer screen will be 'pixelated'. How bad this looks will depend on how good your monitor is. The printed lines shouldn't be affected...
  4. #4
    Forum Newbie
    Using
    AutoCAD LT 2004
    Join Date
    Jul 2012
    Location
    bucks, uk
    Posts
    2
    Default
    Many thanks for those answers - much appreciated. That's a relief.
    I'll have a play with my monitor settings to see if I can improve things, as the effect is quite strong and is really disconcerting
  5. #5
    Senior Member
    Computer Details
    Wilbri's Computer Details
    Operating System:
    MS Windows 7 Professional 64Bit
    Computer:
    Self built
    Motherboard:
    Gigabyte GA-890GPA-UD3H AMD 890GX
    CPU:
    AMD Phenom II X4 965 Black Edition Processor - 3.4GHz
    RAM:
    16 GB DDR3-1600
    Graphics:
    None (AMD FirePro V4900-future)
    Primary Storage:
    SamsungĀ® SATA2 1.5 TB 7200RPM 32MB
    Monitor:
    Samsung BX2450 Monitor 24" Led
    Discipline
    Mechanical
    Wilbri's Discipline Details
    Occupation
    My own business. Design, Drawing, Cost Estimating and Planning
    Discipline
    Mechanical
    Details
    Design Engineer - General mechanical
    Using
    AutoCAD 2007
    Join Date
    Dec 2009
    Location
    South Africa
    Posts
    214
    Default
    Folks I may be barking up the wrong tree here!
    One of the first things I discovered in using AutoCad was that the circles were actually polygons (flat sided) and that this could be overcome by prompting regen. View > Regen, and later discovered that the resolution could be adjusting by typing "viewres"in the command line and increasing the value displayed?
    Would be interested in receiving comments, as I have over the years never had this problem with AutoCad even when using standard office monitors.
  6. #6
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,904
    Default
    It is usual to set viewres to 1000 or greater (I use 2000, have not found any point in going higher). This is fairly common knowledge for anyone who has had professional AutoCAD training.
    Just one of a set of variables I set in my template.
    Set it and forget it.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
Similar Threads
  1. Export properties ("measurement") of "Aligned Dimension" to Excel
    By nhatquyelec in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Feb 2013, 07:58 am
  2. Replies: 17
    Last Post: 24th Jan 2013, 05:34 pm
  3. "Hidden" line turns to "continuous" in layout view
    By jeck in forum AutoCAD General
    Last Post: 19th Jun 2011, 12:44 pm
  4. Another "jagged lines" thread
    By Void in forum AutoCAD Drawing Management & Output
    Last Post: 8th Dec 2009, 05:01 pm
  5. Replies: 1
    Last Post: 25th Nov 2009, 06:35 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
