+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Forum Newbie
    Using
    Civil 3D 2012
    Join Date
    Jul 2012
    Posts
    1
    Default labels on a survey line
    How can I adjust labels on a survey line?
  2. #2
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,791
    Default
    The labels are buried in the "Label Style" you can change these to suit your needs they are a bit complex so start with one that is close, use Edit and save it as another lable do this in your DWT so its always there. Just change one things at a time.
    How can I adjust labels on a survey line? is way to vauge to answer more details required.
  3. #3
    Full Member
    Using
    AutoCAD 2004
    Join Date
    Jan 2008
    Posts
    65
    Default
    Ok, i'm not trying to highjack, but since this thread is open, I didn't want to start another one.
    Here is my problem:
    I have a line labeled with bearing and distance (S58°08'15"E12.99') but as you see there is no space between "S" and "58°", also no space between bearing and distance. How can I change settings so that I don't need to change it manually.
  4. #4
    Super Member Murph_map's Avatar
    Computer Details
    Murph_map's Computer Details
    Operating System:
    XP,Visa, Win7
    Computer:
    HP something or other and the laptop is an HP too
    RAM:
    2 gigs or 6 gigs in Laptop
    Discipline
    Utilities
    Murph_map's Discipline Details
    Occupation
    Boats and campers renting and repairs
    Discipline
    Utilities
    Details
    GIS and Map making.
    Using
    Map 3D 2011
    Join Date
    Feb 2011
    Location
    TN or KY depends if I'm at work or home.
    Posts
    598
    Default
    Quote Originally Posted by naghshe View Post
    Here is my problem:
    Using AutoCAD Civil3D or as your profile says Autocad 2004?
    Murph
    Need a boat or camper for the weekend?
  5. #5
    Full Member
    Using
    AutoCAD 2004
    Join Date
    Jan 2008
    Posts
    65
    Default
    I use Land Desktop 2004.
  6. #6
    Full Member
    Using
    AutoCAD 2004
    Join Date
    Jan 2008
    Posts
    65
    Default
    I found my answer, for those interested...
    Labels---> Edit Label styles
    Under "Units" click on "Angular"---> choose "allow text spaces".
Similar Threads
  1. Replies: 2
    Last Post: 11th Oct 2011, 12:41 pm
  2. survey bearing for line labels - HELP
    By lodom1965 in forum AutoCAD Beginners' Area
    Last Post: 15th Jun 2011, 03:55 pm
  3. Contour labels have line through the center?!?!?
    By courtfetter in forum Civil 3D & LDD
    Last Post: 17th May 2009, 07:45 pm
  4. Reduce the precision of contour line labels
    By Brian_63 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Feb 2009, 01:51 pm
  5. Unwanted spaces in line labels
    By abbrantley in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jun 2007, 04:18 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
