Results 1 to 6 of 6
    Junior Member
    Civil
    Locked and Loaded's Discipline Details
    Draftperson/Designer
    Civil
    AutoCAD 2010
    Jun 2012
    Brisbane, QLD
    10
    Default layout tab crash
    Hello everyone, I got this drawing thats saved in the model tab, when I want to switch to layout tab, it lags and crashes, does anyone know what could be the cause/root of this issue, if not, what would be the best way to work around it? restore a previous version? delete the layout tab, and do it all over again? cheers for all your help in advance.
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Try running -PURGE at the commandline
    and make sure you include the hyphen.
    Command: -PURGE
    Enter type of unused objects to purge
    [Blocks/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SH
    apes/textSTyles/Mlinestyles/Tablestyles/Visualstyles/Regapps/Zero-length
    geometry/Empty text objects/All]: r
    Enter name(s) to purge <*>:
    Verify each name to be purged? [Yes/No] <Y>: n
    Deleting registered application "ACAD_DSTYLE_DIM_EXT1_LINETYPE".
    Deleting registered application "ACAD_DSTYLE_DIM_EXT2_LINETYPE".
    2 registered applications deleted.
    Command:
    -PURGE
    geometry/Empty text objects/All]: a
    Deleting block "*D10".
    Deleting block "*D11".
    2 blocks deleted.
    No unreferenced layers found.
    No unreferenced linetypes found.
    No unreferenced text styles found.
    No unreferenced shape files found.
    No unreferenced dimension styles found.
    No unreferenced mlinestyles found.
    Deleting plotstyle "0.18".
    1 plotstyle deleted.
    No unreferenced table styles found.
    No unreferenced materials found.
    No unreferenced visual styles found.
    No unreferenced multileader styles found.
    No unreferenced groups found.
    Command:
    -PURGE
    geometry/Empty text objects/All]: *Cancel*
    Command:
    Command: _qsave
    Command: AUDIT
    Fix any errors detected? [Yes/No] <N>: y
    Auditing Header
    Auditing Tables
    Auditing Entities Pass 1
    Error for Entry (35873) eInvalidInput was Removed.
    Pass 1 800 objects auditedAcDbSolid(379F9) XData Handle Unknown
    Null
    AcDbSolid(37A15) XData Handle Unknown Null
    Pass 1 2600 objects audited
    Auditing Entities Pass 2
    Pass 2 2600 objects audited
    Auditing Blocks
    48 Blocks audited
    Total errors found 9 fixed 9
    Erased 0 objects
    Command: SAVE
    Junior Member
    Civil
    Civil
    AutoCAD 2010
    Jun 2012
    Brisbane, QLD
    10
    Quote Originally Posted by Dadgad View Post
    Yeah I tried that already and it didn't work...
    AutoCAD 2012
    Nov 2011
    3,134
    Is this a drawing which you did, or somebody else?
    Do you know what software it was done with?
    Have you tried the RECOVER option before opening it?
  5. #5
    Junior Member
    Civil
    Civil
    AutoCAD 2010
    Jun 2012
    Brisbane, QLD
    10
    I dont know who or where the drawing came from it was just given to me from somebody at work. But I ended up running the RECOVERALL command like u said and it seems to work fine. Thankyou for your help, I don't know why I didn't think of it before. to stressed out these days... cheers!
  6. #6
    AutoCAD 2012
    Nov 2011
    3,134
    Excellent, glad you are back in the game.
  1. CAD 2010 crash
    By Jadgpanther in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 13th Sep 2011, 12:28 pm
  2. Crash while Hatching
    By qball in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 8th Apr 2011, 07:57 pm
  3. Hardrive crash
    By Honda Matt in forum AutoCAD General
    Last Post: 7th Feb 2011, 04:16 pm
  4. 3ds max crash
    By nowikovs12 in forum 3D Modelling
    Last Post: 6th Apr 2010, 09:55 pm
  5. OS crash
    By scotteg in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 6th Oct 2009, 11:23 am
