wimal Posted July 18, 2012 Share Posted July 18, 2012 Vertical text properties shows rotation 90 Horizontal text shows rotation 0 Horizon lines angles shows 90 or 270 sample 1.dwg Quote Link to comment Share on other sites More sharing options...
irneb Posted July 18, 2012 Share Posted July 18, 2012 2 things: (1) SnapAng=270 (type SnapAng at command prompt to change) (2) Direction for 0 degrees = North. (type Units and click on the Direction button) Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted July 18, 2012 Share Posted July 18, 2012 Base angle is defined as "North". Type "units", pick "Direction...", set direction to "East". This is default setting. Or type Setvar->angbase->0.0 Quote Link to comment Share on other sites More sharing options...
wimal Posted July 18, 2012 Author Share Posted July 18, 2012 Thanks a lot when I change angbase to 0.0 the it solved the problem Quote Link to comment Share on other sites More sharing options...
