Help to make Pipe in 2d double lineCode:(defun c:DPH()(asave)(command "-layer" "m" "center" "lt" "center" "" "c" "8" "" "m" "pipe" "lt" "continuous" "" "c" "4" "" "")(command "MLINE" "S" "21.34" PAUSE PAUSE "")(command "explode" "l")(command "offset" "10.67" pause pause "" )(command "change" "l" "" "p" "la" "center" "c" "bylayer" "lt" "bylayer" "" "")) (defun c:DP3F()(asave)(command "-layer" "m" "center" "lt" "center" "" "c" "8" "" "m" "pipe" "lt" "continuous" "" "c" "4" "" "")(command "MLINE" "S" "26.67" PAUSE PAUSE "")(command "explode" "l")(command "offset" "13.34" pause pause "" )(command "change" "l" "" "p" "la" "center" "c" "bylayer" "lt" "bylayer" "" ""))
