+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
  1. #1
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Jul 2012
    Posts
    5
    Default Remove objects from selection set
    I have been using autocad for a while and have always been able to use "R" to remove objects from a selection set. All of a sudden now when I want to use that command it activates the "Redraw" command instead of letting me remove objects from my set.
    Does anyone know how to get it back to the way I had it before?
    TIA,
    BWSwede
  2. #2
    Senior Member
    Computer Details
    bill_borec's Computer Details
    Operating System:
    Windows 7 - 64 Bit
    Computer:
    Dell XPS
    CPU:
    Intel i7-2600
    RAM:
    8 GB
    Graphics:
    AMD Radeon HD 6700
    Monitor:
    Dual 24"s
    Discipline
    Civil
    bill_borec's Discipline Details
    Occupation
    Civil PE
    Discipline
    Civil
    Details
    Water Resources (Water/Sewer/Storm) Water/Wastewater Treatment Design
    Using
    Civil 3D 2013
    Join Date
    Jan 2012
    Location
    43.3630N 124.1947W
    Posts
    166
    Default
    When objects are selected, holding shift, then selecting the objects to remove from the selection will work.
    To 'get it back to the way [you] had it before'...I am not sure I understand. The alias 'R' is associated with the 'redraw' command...you could change that with 'aliasedit' and reassign the 'R' to 'remove from selection' i suppose.
    If you have nothing selected and press 'r' you want a redraw, so changing the alias isn't a good idea. IMHO. But with items selected, the shift-select has worked for several years/versions. I haven't been on V2002 in >10 years, so I am not sure anymore.
    Does that answer your question?
  3. #3
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Jul 2012
    Posts
    5
    Default
    Bill,
    Thanks for your reply. The way my autocad was setup and the way it works best for me, is that after I have selected a set of objects and want to remove some of the items, I simple hit "R", window or pick the items I want to remove, and then hit "enter". If while removing items from the set I have removed too many items, I was able to hit "A" and then window or pick items that I want to add back to the set. For some reason neither of these selection tools work. I am thinking that I must have accidently changed a setting in the program, unfortunately I don't know which one.
    Thanks again,
    BWSwede
  4. #4
    Forum Deity MSasu's Avatar
    Discipline
    Construction
    MSasu's Discipline Details
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    3,041
    Default
    Are you talking about creating the said selection set on command prompter before calling an editing command, or while in such command? Or both cases?
    From what I'm concerned Remove and Add are modes of SELECT command and have this meaning only while in this command or in any other editing command that require creation of a selection set. If for you those worked directly on command prompter, then I believe there was a kind of customization active.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  5. #5
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Jul 2012
    Posts
    5
    Default
    I am not sure of your question...
    Experimenting what I just found is that I have to manually start the "select" command by hitting the "s" key for the "r" and "a" functions to work after selecting a set. It didn't use to be this way and now causes me to take an extra step if I want the "r" and "a" functions to work.
    Normally I can window or pick items without initiating any command and the program automatically starts the "select" command. And from there I can add or remove items after selecting them by either using "r" or "a" keys. For some reason, although functionally it works, the automatically started "select" command is not allowing the "r" and "a" functions to work.
    Does what I describe make sense?
    Thank you for replying,
    BWSwede
  6. #6
    Forum Newbie
    Using
    AutoCAD 2002
    Join Date
    Jul 2012
    Posts
    5
    Default
    Hang on guys, I may have found my problem. Look me experiment a bit more.
    Thanks,
    BWSwede
  7. #7
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,176
    Default
    Quote Originally Posted by BWSwede View Post
    Thanks,
    BWSwede
    Welcome to the forum.
    I know just what you mean, that is how it is set up on my system too.
    Life is too short to waste all those uncalled for clicks.
    Confirm your SELECTION tab settings in OPTIONS look like this, windowing style BOTH-AUTOMATIC DETECTION is alright also.
    Whoops, you are on 2002?
    I started in 2008, maybe the information will still help you, hope so.
    Might it be a PICKADD need to be set to 1 issue?
    Volume and repetition do not validate opinions forged in the absence of thought.
  8. #8
    Full Member
    Computer Details
    SAFeSTeR's Computer Details
    Operating System:
    Windows 7
    Discipline
    Utilities
    SAFeSTeR's Discipline Details
    Occupation
    Overhead Cable CAD Technician
    Discipline
    Utilities
    Using
    AutoCAD 2012
    Join Date
    Jul 2012
    Location
    London, England
    Posts
    89
    Default
    I thought using 'r' and 'a' to remove / add selections only worked after a command had been started, at least that's the only way I have used them.
  9. #9
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,176
    Default
    Quote Originally Posted by SAFeSTeR View Post
    Yes, you are correct, they are used transparently midcommand.
    As it is working on my system, although I am using 2012, in the way which you are trying to reconfigure
    I thought that seeing my current settings from the SELECTION tab might shed some light on your problem.
  10. #10
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,176
    Default
    The availability of R & A is only midcommand.
    once you have hit ENTER to complete the selection, you no longer have those shortcut options
    at your disposal and will need to use the SHIFT option as suggested by BillBorec, or use S, as you mentioned in your earlier post.
    Pardon me if I am mistaken, but are you sure you have not forgotten the sequence.
    After hitting ENTER the command modifier shortcuts no longer are valid.
Similar Threads
  1. Remove Proxy objects
    By mathew21 in forum AutoCAD General
    Last Post: 7th Feb 2012, 03:26 am
  2. Remove selection set from another selection set
    By KRBeckman in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jul 2010, 07:20 pm
  3. loop to remove duplicate items from a selection set
    By Hardeight in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jan 2009, 08:55 pm
  4. Can't remove objects
    By nscherneck in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jan 2008, 12:17 pm
  5. delay in selection of objects/selection windows
    By RedRobMol in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2005, 01:34 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
