+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    Jul 2012
    Posts
    3
    Exclamation Urgent'''''''' need help for Extending the width of a frame shaped solid
    I tried every single way to try to extend the with of the hole body
    but it's not working in any way
    The problem is its a solid body which looks like a rectangle shape frame,
    and i made it as a hole union which i cant simply extend the top and the bottom widths.
    Please do help ;(((((
    Thank You
  2. #2
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,131
    Default
    Welcome to the forum.
    If you use the SLICE command you can cut it in half (at the midpoint along the axis which you want to extend).
    I like to use a CIRCLE as a slicing OBJECT, you could also define it by PLANE, once you start the SLICE command.
    After you cut it in half switch to an ISOMETRIC view so that you can better see what you are doing.
    Turn on ORTHO, then you can use PRESSPULL on the faces which you need to lengthen.
    Only lengthen them by half of the total distance by which you want to stretch your frame.
    Once you have the appropriate horizontal members lengthened you can switch to TOP view
    and MIRROR your 3D solid about the center point (defined by the newly stretched horizontal members).
    Go back into an ISOMETRIC perspective, or use ORBIT to confirm that everything looks good
    before you use the UNION command to put it all back together with the new length.
    You could also use the 3DMIRROR command directly from your isometric view without going back to
    TOP view, but if you are not familiar with it, just using MIRROR from TOP view will do the same thing.
    Volume and repetition do not validate opinions forged in the absence of thought.
  3. #3
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    Jul 2012
    Posts
    3
    Default
    Quote Originally Posted by Dadgad View Post
    will be pleased if you can give m some kind of tutorial, as im a new AutoCad user working in a company as eningeering trainee =(
    Tons of thanks
  4. #4
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    Jul 2012
    Posts
    3
    Default
    Thats the body i create, and i circled the way i want it extend
  5. #5
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,131
    Default
    Look at the images and you will see the sequence of steps I used to lengthen the unioned bench.
    In Top view I drew a line to identify the midpoint of the items which I wanted to lengthen, crossing the axis which I wanted to lengthen.
    I switched to an ISOMETRIC view, the better to see what is about to happen in 3 dimensions.
    Using the SLICE command, I selected the 3 horizontal slats (which I need to cut to half of their desired overall length).
    I defined the SLICING plane with the YZ option, then selected the endpoint of (or any point on) the midpoint line, and executed the command.
    After slicing the bench I deleted the left over legs.
    I used the PRESSSPULL command to PULL each of those horizontal members by 300mm, in succession.
    I then used the MIRROR3D command to mirror the newly lengthened half bench into the full length item.
    I then used the UNION command to reassemble them into a single SOLID entity.
    The example I did was very much like the one you are going to do, just take your time, and you will do fine with it.
    Obviously this same technique can be applied on any axii you choose.
  6. #6
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,092
    Default Quick & Easy
    _solidedit>_face>_move
  7. #7
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,131
    Default
    Quote Originally Posted by SLW210 View Post
    Good point!
Similar Threads
  1. Convert wire frame to solid...
    By capac in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Apr 2010, 08:48 pm
  2. Converting a wire frame to 3D solid
    By neo_clear in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Mar 2010, 09:42 am
  3. Wire Frame 2 Solid
    By Nur in forum AutoCAD Beginners' Area
    Last Post: 24th Nov 2006, 04:07 pm
  4. 3d wire frame or solid modelling?
    By comcu in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Aug 2006, 07:43 pm
  5. creating an egg shaped solid
    By johnfulwyler in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Nov 2003, 10:22 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
