Results 1 to 2 of 2
    Full Member
    Inventor 2011
    Apr 2012
    27
    Default Point Location on Screen- Mouse Movement
    One more question (Inventor 2011):
    In Sketch Mode, when I scroll my mouse over a vertex point, the point is highlighted. When I look down in the lower-right corner to read the X,Y position of the point, the numbers change with the slightest mouse movement, even though the point remains highlighted all the while. So: when a point is highlighted (when I scroll over it), doesn't that mean I am 'on'/'at' that point? Why does the X,Y position 'readout' fluctuate, then? Many thanks, again.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Been using Inventor for 10 years and never paid a half second attention to that.
    I think the general idea it is a guide to sketch your first line, arc or circle approximate size for scale and then forget it.
    2013 takes care of scale for you when you start dimensioning.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  1. Mouse that does not slip - relative input to screen.
    By deano33 in forum AutoCAD General
    Last Post: 3rd Jul 2012, 09:40 pm
  2. Zoom to mouse location
    By npbsurfr in forum AutoCAD Beginners' Area
    Last Post: 15th Aug 2011, 02:31 am
  3. Reversing mouse scroll wheel zoom movement...
    By Gar in forum Autodesk Inventor
    Last Post: 5th Feb 2007, 12:05 am
  4. cursor and point location
    By Gene in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jul 2006, 04:36 pm
  5. Problem: AutoCAD mouse pointer sticks on the screen
    By Jim25 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Apr 2006, 11:32 pm
