Results 1 to 8 of 8
    Full Member
    not applicable
    Mar 2012
    46
    Default drawing/stretching a line so it ends above a given point
    I'm starting to draw a line and I want it to end above a point so that the next line I draw will be perpendicular to the first line and will end at the point. E.g., in the attached picture, I'm starting to draw the orange line and want it to end above the top-right corner of the rectangle.
    How can I do that?.
    I don't know how high the line above the point (so can't use 'fro')
    Regards,
    Ittay
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Welcome to the forum.
    Turn on your OBJECT SNAP TRACKING and other values as shown in the image of the OSNAP tab of the DRAFTING SETTINGS dialogue box.
    After starting your line by selecting the first point, HOVER over the grip which is at the corner of the box.
    Do not click on it, and the program will acquire the X value of that point, then move up toward the line you are creating and you will
    see a tracking vector generated which will include a snappable point of intersection with your new line.
    Turn on your ORTHOGONAL MODE to avoid any issues.
    I suppose you could use parametric constraints too, but that is a whole different can of worms
    and seems over the top for such a simple case. But you should know that they are available and very good tools.
    I have succeeded in making this sound really difficult, which it is not.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,968
    Simply use the Perpendicular Osnap, and click on the right hand line of the rectangle.
    AutoCAD 2012
    Nov 2011
    3,134
    Quote Originally Posted by eldon View Post
    Good call eldon!
    I use the PERPENDICULAR snap a lot, but I never knew it would do that, I thought it would only work if the line actually crossed it.
    I also use APPARENT INTERSECTION a lot.
    I knew I had made that harder than it needed to be!
  5. #5
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    I would just use tracking and I leave on polar tracking as it is the same as ortho only more.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  6. #6
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    Old fashioned way .X .Y etc
    Start line then .x pick new line for y
  7. #7
    AutoCAD 2012
    Nov 2011
    3,134
    So many different ways to go.
    So much to learn, so little time.
  8. #8
    Forum Newbie
    AutoCAD LT 2010
    Jul 2012
    4
    just simply "strech commad" will do just make sure to turn polar and otrack buttons on
    Command: s STRETCH
    Select objects to stretch by crossing-window or crossing-polygon...
    Select objects: Specify opposite corner: 1 found
    Select objects:
    Specify base point or [Displacement] <Displacement>:
    Specify second point or <use first point as displacement>:untitled.jpg
  1. Drawing a line with one or two arrow ends
    By titech in forum AutoCAD General
    Last Post: 25th Oct 2012, 12:29 pm
  2. drawing line from a point between 2 objects
    By luke83 in forum AutoCAD Beginners' Area
    Last Post: 15th Mar 2010, 02:14 pm
  3. special ends on line object
    By JerryFiedler in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Aug 2009, 10:15 am
  4. special ends on line objects
    By JerryFiedler in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Jun 2009, 05:10 pm
  5. Where one point on a drawing ends up on another
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2006, 12:26 pm
