+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Full Member
    Using
    AutoCAD 2012
    Join Date
    May 2012
    Posts
    55
    Default Transfer from Trimble to Map 3d 2013
    If there a specific forum on here related to Map 3d 2012? Cant find it anywhere,
    Having a problem with data transfer from a hand held Trimble unit to Cad.
    Need help asap....
    Thanks,
  2. #2
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,128
    Default
    Yes, I just moved you to the Map 3D forum.
    It is listed as a child forum under AutoCAD Vertical Products.
  3. #3
    Full Member
    Using
    AutoCAD 2012
    Join Date
    May 2012
    Posts
    55
    Default
    Ok thanks!
    I am transfering data from the hand held Trimble unit to DXF. I can open the data file using GPS pathfinder office software, viewing the data is fine, checking the measurments makes sense. I have NAD1983 as a co-ord system set in the controller and in Pathfinder office software. I export the file to dxf and "insert" the dxf as a block. When looking at the file and checking distances in Map 3d.... the distances are very small. Something has happened when converting the file to dxf, Not sure where to look or what to change. I know there is a co-ord system in Map 3d and I believe I am on NAD83, Does this effect the dxf being inserted?
    Thanks,
    Lost Mike
  4. #4
    Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    RAM:
    4 GB RAM
    Graphics:
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,128
    Default
    I updated your thread title to "Transfer from Trimble to Map 3d 2013".
  5. #5
    Senior Member Emigrato's Avatar
    Using
    not applicable
    Join Date
    Sep 2011
    Posts
    116
    Default
    I'd bet those distances are small, 'cause your survey stuff belongs to a Lat/Long CRS, e.g. EPSG:4326
  6. #6
    Super Member Murph_map's Avatar
    Computer Details
    Murph_map's Computer Details
    Operating System:
    XP,Visa, Win7
    Computer:
    HP something or other and the laptop is an HP too
    RAM:
    2 gigs or 6 gigs in Laptop
    Discipline
    Utilities
    Murph_map's Discipline Details
    Occupation
    Boats and campers renting and repairs
    Discipline
    Utilities
    Details
    GIS and Map making.
    Using
    Map 3D 2011
    Join Date
    Feb 2011
    Location
    TN or KY depends if I'm at work or home.
    Posts
    598
    Default
    Quote Originally Posted by MichaelH27 View Post
    Ok thanks!
    Thanks,
    Lost Mike
    I would suggest not to use the DXF format but export from Pathfinder Office to ESRI SHP format then use eith Mapimport to import into AutoCAD Map3D or use data connect to connect to the shp file.
    Murph
    Need a boat or camper for the weekend?
Similar Threads
  1. Inventor 2013 & Inventor LT 2013 System Requirements
    By jdits7 in forum Autodesk Inventor
    Last Post: 6th Apr 2012, 02:48 pm
  2. Trimble Link 4 Civil Cad 2011
    By christreeroot in forum Civil 3D & LDD
    Last Post: 22nd Mar 2011, 12:44 am
  3. Questions using Trimble TSC2
    By Martini in forum Civil 3D & LDD
    Last Post: 20th Aug 2010, 01:39 am
  4. Trimble Link Tab
    By Coral in forum AutoCAD General
    Last Post: 23rd Apr 2010, 04:23 pm
  5. Transfer a jpg to a mli?
    By Jamalama in forum AutoCAD General
    Last Post: 10th Mar 2005, 03:22 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
