+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Forum Newbie
    Using
    AutoCAD 2004
    Join Date
    Jul 2012
    Posts
    3
    Question I lost all of the Short Key Commands I got a Message Unknown Command Press F1 4help
    Hi,
    I hope some one can help me. I'm an Autocad 2004 user and I was working in a auto cad drawing and I wanted to install a new hatch file and now I cannot get any of my short key commands, Z zoom, Line, Circle, Etc. every time that I enter a command I get a message saying Unknown command Press F1 for help.
    I will really appreciate your input on how to get the commands files to work again
  2. #2
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell Precision T7500
    CPU:
    Xeon Dual Core E5503 2.0Ghz
    RAM:
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    Graphics:
    nVidia Quadro 3800
    Primary Storage:
    300Gb, 10K rpm
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2014
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    3,375
    Default
    At the command line type
    (findfile "acad.pgp")
    hit enter.
    Does it return a path to it? If no, use search in windows file explorer to locate which folder it is in.
    Then go to Option in Autocad, Files, support file search path, confirm that that path is in there, if not pick add, then browse, and browse to that folder. Hit OK to exit, you should be good to go, if not try REINIT, pick PGP file, OK.
    If the original search says it found it then try DEMANDLOAD and set it to 3. (you type that at the command line and hit enter, then 3, enter. Just in case you are really new to the program.)
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  3. #3
    Forum Newbie
    Using
    AutoCAD 2004
    Join Date
    Jul 2012
    Posts
    3
    Default
    Thank you Very Much rkent,
    I was able to locate the file now by serching using the Option in Autocad. I reinserted the path and now its Working Fine
    Thanks alot for your help and letting me know the name of the file to search for.
Similar Threads
  1. Short commands not working
    By kamig in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 2nd May 2012, 01:43 pm
  2. Unknown command "_check". Press F1 for help.
    By ahyin in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Dec 2011, 08:49 am
  3. Unknown command "-BEDIT". Press F1 for help.
    By tutt in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Feb 2011, 03:18 pm
  4. Can't use short commands anymore
    By Organic in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 12th Feb 2009, 03:36 pm
  5. Unknown command "SYNTAX". Press F1 for help..... why?
    By Lee Mac in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Aug 2008, 07:15 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
