Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Junior Member
    AutoCAD 2013
    Jul 2012
    13
    Default Adding objects to layers - FNG here
    I am just learning AC and have the tutorial video by Brian Benton for 2012. He does a great job of explaining what layers are and how to manage them once they have been created but he does not touch on how to add objects to a layer after you create it??? I watched the layers section 4 times and nothing about this.
    I can create a new layer fine and also a new object but unless I am just blind and stupid (which is possible) I do not see any options in the layer manager letting you add an object to a layer? Got--- create new layer, freeze layer, isolate layer, etc, etc, etc but nothing to do the simple and most basic task of adding your newly created object to a layer-----either a newly created one you just made or an existing one? Any help would be great. Thanks in advance.
    Brian
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 7 Home Premium (H)
    Lenovo ThinkStation D20 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Xeon E5503 (W)/AMD Athlon 2 X4 (H)
    4 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Quadro FX 580 (W)/nVidia GF GT430 (H)
    500 GB HDD (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Dell 22" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management
    AutoCAD 2012
    Sep 2002
    Winston-Salem, NC - USA
    4,446
    Just select the objects and then use the layer pull down and select a new layer. The items should be on the new layer. That easy
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ - - http://cad-guy.tumblr.com/ -
    Junior Member
    AutoCAD 2013
    Jul 2012
    13
    Thanks but - yeah, would think it would be that easy but I have tried every permutation of that and layer options there are. I must have some setting enabled that is doing undesirable things to my layers.??? I select the objects and go to their properties and it shows that I have them on the correct layer....but when I am in model space and select the objects the command line indicates they are on the current active layer, which is not where I want them??? I have all layers turned on exit out of all commands and the objects are not the color of the layer I assigned them to. I am quite vexed at this point. Thoughts?
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    Archibus Management
    AutoCAD 2012
    Sep 2002
    4,446
    Are you drawing "by layer" by this I mean are all setting in the Properties pallet set to "by layer"?
    With this setting all items take the properties that you set in the layer manager when you created the layer. When that particular layer is active.
  5. #5
    Junior Member
    AutoCAD 2013
    Jul 2012
    13
    yup- heres what I got..
  6. #6
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    Archibus Management
    AutoCAD 2012
    Sep 2002
    4,446
    Well I can almost read it Is that per chance a block? If so it was created on that green layer and not drawn by-layer and it will not take on the properties of the inserted layer, looks like a red colored layer. Double click on that item and see what happens.
    Send me the file if you want to. I'll take a look.
    f700es<at>yahoo<dot>com
  7. #7
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    You have an associative array there so it acts like a block. The object may be on one layer but if you create the array on another then it will say it is on that layer while using the object from another layer. Explode the array (at least temporarily) to see the result.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  8. #8
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    Archibus Management
    AutoCAD 2012
    Sep 2002
    4,446
    Ah so it is a triangle, got to get my eyes checked. Thought it was a square
  9. #9
    Junior Member
    AutoCAD 2013
    Jul 2012
    13
    sorry about the first pic...just installed Snagit so I can get better shots......try this..... this is a rectangular array so object or block? Again newby so still figuring out who is what etc...7-24-2012 3-36-41 PM.jpg
  10. #10
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    From 2013 help file
    Associative. Items are contained in a single array object, similar to a block.
  1. Adding Layers to Drawings in Bulk
    By AIS Dan in forum AutoCAD Drawing Management & Output
    Last Post: 25th Apr 2012, 05:22 pm
  2. Adding Materials/Textures to 2D Objects
    By Stryker1989 in forum AutoCAD Beginners' Area
    Last Post: 24th Aug 2011, 01:33 pm
  3. Adding text to 3D Objects
    By Dan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Oct 2006, 05:16 am
  4. Adding Layers from one drawing to another
    By king3471 in forum AutoCAD Beginners' Area
    Last Post: 17th Sep 2005, 02:37 pm
  5. Adding objects to a tool pallette
    By ziemerd in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Oct 2004, 11:48 am
