Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Full Member Lewis C's Avatar
    Lewis C's Computer Details
    Windows 7 64 Bit
    HP Z210 CMT Workstation
    i7-2600K @ 3.40 GHz
    8 GB
    AMD FirePro V5900 2GB GDDR5
    HP ZR2240w - HP LA1951g
    Inventor 2013
    May 2012
    Hampshire UK
    57
    Default Inventor image renderer?
    Hello, I would like to know if there is another program or plugin you can use with Inventor to produce photorealistic images.
    Solidworks have an additional program called Photoview 360. Does anybody know of a similar product to use with Inventor??
    Many Thanks.
    Windows 7 64 Bit
    i7-2600K @ 3.40 GHz
    8 GB
    Inventor 2013
    May 2012
    Hampshire UK
    57
    Anybody know of one?
    Windows 7 64 Bit
    i7-2600K @ 3.40 GHz
    8 GB
    Inventor 2013
    May 2012
    Hampshire UK
    57
    Ill take this as a no.
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
    Wow, you waited less than 2hrs for a response?
    Do you have Inventor Studio?
  5. #5
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Quote Originally Posted by Lewis C View Post
    Then I won't give you the two solutions.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  6. #6
    Windows 7 64 Bit
    i7-2600K @ 3.40 GHz
    8 GB
    Inventor 2013
    May 2012
    Hampshire UK
    57
    Hello sorry for my impatience. Umm yes I do have inventor studio, under the environments tab.
    JD, can you please tell me the two solutions?
    Thank you.
  7. #7
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    You have found the "free" (free in that it is included in Inventor) solution - Inventor Studio.
    Also Inventor Publisher. http://usa.autodesk.com/adsk/servlet...&siteID=123112
    If you are a student you can download Inventor Publisher for free as well from http://www.autodesk.com/edcommunity
  8. #8
    Windows 7 64 Bit
    i7-2600K @ 3.40 GHz
    8 GB
    Inventor 2013
    May 2012
    Hampshire UK
    57
    Publisher looks very good, does it produce photo realistic images? If so thats exactly what i'm after. I am not happy with the options you have within Inventor, they are very basic and I cannot set the level of DPI, or lighting properly. Studio is better for that as you can set the DPI, change the lights e.g. spot/point light but you cannot output images using the realistic option, only illustrative or shaded, which I find very annoying.
    Also I have just found a program called Keyshot, it looks very good aswell, and apparently compatible with Inventor. Do you have any experience or advice about this program?
  9. #9
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,128
    Check out the SHOWCASE forum several there use Keyshot.
    Post questions about Keyshot in the DESIGN SOFTWARE forum.
  10. #10
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    ...but you cannot output images using the realistic option, ...
    Sure you can.
  1. 2013 iray renderer monochromatic
    By nowikovs12 in forum Cameras, Lighting & Rendering
    Last Post: 22nd May 2012, 03:54 pm
  2. Super urgent... Bout my graduation, renderer keeps corrupt
    By yun3683387 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 6th Mar 2011, 06:52 am
  3. XREF Image To AutoCAD To Inventor 2009
    By vertical horizons in forum Autodesk Inventor
    Last Post: 2nd Jun 2010, 07:01 pm
  4. Screen renderer shows black screen
    By cameroon95 in forum Cameras, Lighting & Rendering
    Last Post: 4th Nov 2009, 05:23 pm
  5. Renderer for SketchUp??
    By StykFacE in forum SketchUp
    Last Post: 31st Oct 2007, 02:48 pm
