Try something simple like:
Code:(defun c:rv ( / *error* ar bn cm el fn rv ) (setq bn "Rev# Block") ;; Rev Cloud Attributed Block (defun *error* ( msg ) (if cm (setvar 'cmdecho cm)) (if ar (setvar 'attreq ar)) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (setq cm (getvar 'cmdecho) ar (getvar 'attreq) ) (cond ( (not (or (tblsearch "BLOCK" bn) (and (setq fn (findfile (strcat bn ".dwg"))) (progn (setvar 'cmdecho 0) (command "_.-insert" fn nil) (setvar 'cmdecho cm) (tblsearch "BLOCK" bn) ) ) ) ) (princ (strcat "\n" bn ".dwg not found.")) ) ( (zerop (logand 2 (cdr (assoc 70 (tblsearch "BLOCK" bn))))) (princ (strcat "\n" bn " not attributed.")) ) ( (setq *rev* (cond ( (= "" (setq rv (getstring t (strcat "\nSpecify Revision" (if *rev* (strcat " <" *rev* ">: ") ": "))))) *rev* ) ( rv ) ) ) (command "_.revcloud") (while (= 1 (logand 1 (getvar 'cmdactive))) (command "\\")) (setvar 'cmdecho 0) (setvar 'attreq 0) (setq el (entlast)) (princ "\nSpecify Point for Revision Block: ") (command "_.-insert" bn "_S" 1.0 "_R" 0.0 "\\") (if (not (eq el (setq el (entlast)))) (progn (setq el (entget (entnext el))) (if (entmod (subst (cons 1 *rev*) (assoc 1 el) el)) (entupd (cdr (assoc -1 el))) ) ) ) (setvar 'attreq ar) (setvar 'cmdecho cm) ) ) (princ) ) (princ)
