Results 1 to 2 of 2
    Full Member
    Architecture 2008
    Dec 2009
    75
    Default Autocad 2010 door/window assembly does not show on 3D wall
    Hello,
    I have a 30 cm wall (composed of 2 components).
    When I add a door/window assembly (which is a window) the window does not appear in realistic visual style 3D.
    some walls are OK and some walls with same style does not show any window when displaying Realistic Visual Style 3D.
    Please help.
    Full Member
    Architecture 2008
    Dec 2009
    75
    Hello all,
    I found the reason for that case. A warning on the wall (the known yello triangle) prevents the windows to be displayed on 3D.
    Please advise if this can be override so the window will be displayed even if there is a warning on the wall.
    Thanks.
  1. Replies: 6
    Last Post: 3rd May 2012, 07:54 pm
  2. Door in a curtain wall - overide frame?
    By busseynova in forum Architecture & ADT
    Last Post: 29th Apr 2012, 02:45 pm
  3. Synchronizing wall and door property sets - Need help!
    By BrianClarke in forum AutoCAD General
    Last Post: 6th Apr 2011, 04:34 pm
  4. Replies: 0
    Last Post: 14th Jul 2009, 08:53 am
  5. How do I overlap a door onto a wall?
    By diwaker in forum AutoCAD General
    Last Post: 22nd Dec 2005, 10:57 pm
