+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Junior Member Print_Master's Avatar
    Computer Details
    Print_Master's Computer Details
    Operating System:
    Windows 7
    Computer:
    HP
    Monitor:
    View Sonic 26" (2)
    Using
    AutoCAD 2013
    Join Date
    Jun 2012
    Location
    USA
    Posts
    14
    Default External References vs. Underlays
    I am working on making a Dwg file size smaller. Keep locking up the computer. I was wondering what would be better to use to help keeping the file size small? Thanks.
  2. #2
    Senior Member
    Computer Details
    bill_borec's Computer Details
    Operating System:
    Windows 7 - 64 Bit
    Computer:
    Dell XPS
    CPU:
    Intel i7-2600
    RAM:
    8 GB
    Graphics:
    AMD Radeon HD 6700
    Monitor:
    Dual 24"s
    Discipline
    Civil
    bill_borec's Discipline Details
    Occupation
    Civil PE
    Discipline
    Civil
    Details
    Water Resources (Water/Sewer/Storm) Water/Wastewater Treatment Design
    Using
    Civil 3D 2013
    Join Date
    Jan 2012
    Location
    43.3630N 124.1947W
    Posts
    166
    Default
    I am a fan of the XREF.
    Other things you can do to shrink a DWG file size is to run purge and/or audit. Purge will remove un-used layers/blocks/etc.
    How big of a file are we talking, here? What kind of computer specs do you have to work with?
  3. #3
    Full Member
    Using
    AutoCAD 2010
    Join Date
    Aug 2009
    Location
    Ontario, Canada
    Posts
    56
    Default
    Sounds like you have insufficient ram in your computer.
    From my understanding, Xref's and Underlays behave the same way in AutoCAD. Both are seperate drawings (or other file types) that are linked to your AutoCAD drawing file. It does help keep your main drawing file small. However, AutoCAD still loads all the information stored in your Xref or Underlay when you open your drawing file. This can cause your ram to get all used up, or slow down your processor as AutoCAD loads everything up. Consider keeping your Xref or Underlay turned off if you don't really need them.
    Another helpfull tip to keep file sizes smaller is to use blocks as often as possible where you have multiple identical objects/parts/components/symbols/etc... And as Bill_borec mentioned, run purge on a regular basis.
    Consider splitting up your large file into several smaller sizes. For example, if you're doing architectural drawings, have one file contain the floor plans, a second file for your details, a third for your elevations, etc... I've had to do this on several occasions.
    How much ram does your computer have? Does your DWG file have 3D solid models in it?
    At what point in your drawing does your computer lock up? Is it when working in model space or paper space? Sometimes the number of viewports in one layout tab can cause your computer to lockup if you have insufficient ram.
  4. #4
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,134
    Default
    Set your ISAVEPERCENT to 0, or at least a smaller value than the default 50.
    With ISAVE PERCENT set to 50 your drawing file could be bloated by as much as 50% of the clean size.
    Meaning that your drawing COULD POTENTIALLY be reduced by as much as 1/3 of the current size by this simple step.
    The ' -PURGE ' (include the hyphen when you enter it at the commandline) will do a more comprehensive purge than the regular PURGE command.
    Volume and repetition do not validate opinions forged in the absence of thought.
  5. #5
    Super Member RobDraw's Avatar
    Using
    AutoCAD 2011
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    1,236
    Default
    Quote Originally Posted by Print_Master View Post
    Does the file reference other files?
    Rob
  6. #6
    Computer Details
    Operating System:
    Windows 7
    Computer:
    HP
    Monitor:
    View Sonic 26" (2)
    Using
    AutoCAD 2013
    Join Date
    Jun 2012
    Location
    USA
    Posts
    14
    Default
    @denimoth it lags when I scroll in and out, but locks up when change from model to layout and layout to model space. Also takes a while for to reconize my commands.
  7. #7
    Computer Details
    Operating System:
    Windows 7
    Computer:
    HP
    Monitor:
    View Sonic 26" (2)
    Using
    AutoCAD 2013
    Join Date
    Jun 2012
    Location
    USA
    Posts
    14
    Default
    I have listed some information based off of what all you have wrote back. I also have taken everything in to count.
    Thank you guys for all of your help!
    @bill_borec I have been using purge on a regular basis, and I am currently cleaning up all the unwanted layers.
    @bill_borec & @Denimoth Computer Details: Windows XP Professional Intel Core i5 @2.50GHz 2.49Ghz, 2.94GB of RAM
    @Denimoth I have already made everything a block in all the dwg, and do have it devided up into catagories like you stated.
    @Dadgad I just put it to 0 for the ISAVEPERCENT.
    @RobDraw I do reference other files as well.
    I will keep you posted on if all the inputs that you have given me have worked.
    Thanks.
  8. #8
    Using
    AutoCAD 2011
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    1,236
    Default
    The problem is more than likely in one of the XREF'd files. Even just one attribute that is not a part of a block can cause what you are experiencing. Make sure your XREFs are cleaned up. The fastest/easiest way to do this is to WBLOCK just what you need from them.
    Rob
  9. #9
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,134
    Default
    Are you REGENERATING WHEN SWITCHING LAYOUTS, as shown in OPTIONS in the image?
Similar Threads
  1. External references
    By jitu in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jul 2012, 10:19 am
  2. External references
    By Leelee in forum AutoCAD General
    Last Post: 31st Jan 2012, 02:48 pm
  3. External references
    By Jfennell in forum AutoCAD Beginners' Area
    Last Post: 30th Jun 2008, 08:54 pm
  4. External references
    By Shiloh in forum AutoCAD General
    Last Post: 20th Dec 2007, 10:41 am
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
