+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
  1. #21
    Full Member
    Using
    AutoCAD 2013
    Join Date
    Jul 2012
    Posts
    51
    Default
    guyssss thanksss alot it finaly worked !! ... aiam not sure why is it .. propaly because i have to set the record on before i do any change to the shape xD ... thanks aloott you guys .. you helped me tonss to figuer alott of things out with the little codes u gave me
    i have one question tho .... if i want the history record to be ON as defualt even before i draw anything ... how to do that ???
  2. #22
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,131
    Default
    I am very happy to hear that you finally got it to work.
    I thought we had covered that one in post # 11?
    In addition to having your SOLIDHIST to 1, you will notice that I have selected in the palette to RECORD, the default is NONE.
    Once you do that it will all start to work for you.
    As just about anything you draw in the program could be the first step of a new solid history
    I believe you will need to RECORD, when you want it to.
    I know it is difficult having so many different approaches and suggestions being offered
    all at the same time, but if a suggestion is made, the forum members have to assume that it has been tried,
    and failed, unless we hear otherwise, which leaves us no other choice than to try a different solution.
    Volume and repetition do not validate opinions forged in the absence of thought.
  3. #23
    Full Member
    Using
    AutoCAD 2013
    Join Date
    Jul 2012
    Posts
    51
    Default
    Quote Originally Posted by Dadgad View Post
    ya its finaly working .. thanks to you man for all what u did for me
    you are pretty great
  4. #24
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,131
    Default
    You're entirely welcome.
    At CADtutor, we all aim to please.
Similar Threads
  1. AutoCAD History
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 4th Oct 2011, 06:29 pm
  2. drawing history
    By bjenk8100 in forum AutoCAD General
    Last Post: 18th May 2011, 05:24 pm
  3. Drawing History
    By skipsophrenic in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jul 2009, 01:32 pm
  4. Remove Solid History from All Blocks
    By Delphi1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jan 2009, 12:18 am
  5. CTB File History
    By chulse in forum AutoCAD Drawing Management & Output
    Last Post: 6th Sep 2007, 05:40 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
