Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Full Member
    Inventor 2012
    Oct 2011
    40
    Default Create plane parallel to taper
    Hi
    I'm trying to create a plane parallel to a tapered edge. I need this plane to create a sketch and use this to cut extrude the shape onto the tapered shaft as an inlay. All I can get is the default plane which is parallel to the axis only.
    Probably a pretty basic action but I need some help.
    Thanks
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    If you don't already have a sketch line (used to create the taper?), then -
    Create sketch on plane perp to tapered edge.
    Project Cut Edges.
    Exit sketch and create workplane by selecting the angled line and the plane on which you created the sketch.
    If this isn't what you want - attach your file (or a representative example) here.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Full Member
    Inventor 2012
    Oct 2011
    40
    Hi
    Thanks for getting back. The file attached is an example of the part with which I am working. I need to be able to cut a groove in the curved area for inlay. I also need to be able to do this on a tapered surface. The parts are not generated by revolving about an axis but by a loft between circles. Any advice would be appreciated.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    I'm going to be away from my Inventor computer for a bit - hopefully someone else will come along and follow up on this question.
  5. #5
    Senior Member
    Bishop's Computer Details
    Windows 7 Enterprise
    Dell Precision T1600
    Xeon E3-1280
    16 GB
    Quadro 600 1024 MB
    Seagate 250GB - ST3250312AS
    Western Digital 1024 GB - External
    2x Dell P2211H @ 1920 x 1080
    Multi-disciplinary
    Bishop's Discipline Details
    CAD Design, Manufacturing
    Multi-disciplinary
    Inventor 2013
    Nov 2009
    People's Republic of California
    321
    I only have 2011 at work so I can't check out your parts, but ... based on the filename, this is extremely relevant to my interests. If I'm right, then "I've got Naill's" should make sense to you, DeRabes?
  6. #6
    Full Member
    Inventor 2012
    Oct 2011
    40
    'fraid not, Bishop
  7. #7
    Senior Member
    Xeon E3-1280
    16 GB
    Quadro 600 1024 MB
    Multi-disciplinary
    Multi-disciplinary
    Inventor 2013
    Nov 2009
    321
    Hm. A chanter, though? For pipes?
  8. #8
    Full Member
    Inventor 2012
    Oct 2011
    40
    Yep. Ups actually. Don't get the "I've got nails" thing though.
  9. #9
    Senior Member
    Xeon E3-1280
    16 GB
    Quadro 600 1024 MB
    Multi-disciplinary
    Multi-disciplinary
    Inventor 2013
    Nov 2009
    321
    Naill. David Naill is one of the bigger pipe makers, that's who made mine.
  10. #10
    Junior Member
    abstracted's Computer Details
    Vista 7 64bit
    Inventor 2013
    Jul 2008
    Dallas, Texas
    13
    All you need to do is create a point on the tapered face. Then (with the workplane command active) click on the point, then click on the tapered face.
    In the image (i'm assuming I chose the right tapered face you were talking about), the top plane is just an offset of the tangent plane. You can barely see the point in the center of the bottom plane.
  1. [Help] I'm finding lisp copy from XZ plane to XY Plane
    By ketxu in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Oct 2011, 10:48 am
  2. Replies: 3
    Last Post: 14th Dec 2010, 10:00 pm
  3. Create a plane at the center of a solid3D
    By IsraelM in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Mar 2010, 01:43 pm
  4. How do I create a Angled Work Plane
    By Red_Stafford in forum Autodesk Inventor
    Last Post: 3rd Mar 2009, 05:52 pm
  5. Create Parallel Linetypes
    By jbl2000 in forum AutoCAD General
    Last Post: 13th Jun 2005, 07:43 pm
