michael256 Posted July 30, 2012 Share Posted July 30, 2012 Im pretty new to annotative text. I was wondering how I can make text show in two viewports at two diffrent scales? Also how to I remove scales from text? Any help would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 30, 2012 Share Posted July 30, 2012 I usually select the object and use the properties palette. Quote Link to comment Share on other sites More sharing options...
rickh Posted July 30, 2012 Share Posted July 30, 2012 I normally pick the annotative object or objects, right click (with right click set to show shortcut menu), "annotative object scale" --> "Add/delete scales" or just type "objectscale" as a command, follow the prompts to add/delete. or on the ribbon, Annotate Tab, "Add/Delete Scales" Since you are working with annotative objects, you may want to also look into the settings of ANNOAUTOSCALE and ANNOALLVISIBLE to make life easier (these are the icons next to the current scale in the lower right portion of screen). You can just type the word, press enter, then F1 key for the help documents. Quote Link to comment Share on other sites More sharing options...
