Results 1 to 8 of 8
    Forum Newbie
    Lateralg's Computer Details
    Win7 Home Premium
    Dell XPS 17
    Quad core i7 2-nd generation
    8GB
    ? 1+1 GB
    500 GB
    599 GB
    22"
    Mechanical
    Lateralg's Discipline Details
    Retired Auto Engineer
    Mechanical
    Using and improving RepRap 3D printing.
    Inventor 2013
    Jul 2012
    Live in Howell, MI in summer, Green Valley, AZ in winter
    6
    Default OSNAP settings in Inventor
    Where are osnap settings, or their equivalent, in Inventor 2013?
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,133
    Quote Originally Posted by Lateralg View Post
    Welcome to the forum.
    I don't really know how to use it, but in INVENTOR FUSION there is an ICON in the lower right corner, looks like a series of linked red lines with SNAP POINTS.
    Could it be that the snaps in INVENTOR are sort of autonomous, and always on by default?
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,099
    I moved your post to a new thread in Autodesk Inventor forum.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    You should never need to fool with them.
    To get to them, while in sketch right click and select Constraint Options (or something like that - I'm not at my Inventor computer right now and as I stated in 10 years of using Inventor I never had to fool with them.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Forum Newbie
    Win7 Home Premium
    Dell XPS 17
    8GB
    ? 1+1 GB
    500 GB
    599 GB
    22"
    Mechanical
    Mechanical
    Inventor 2013
    Jul 2012
    6
    Quote Originally Posted by JD Mather View Post
    That's good news and bad news. Good that there's apparently a way to do what I need to; bad that I have no idea how to do it.
    When I right click > select snap points > I see only Midpoint, Center, Intersection as options.
    I need endpoint, but don't see a way to get it. Maybe there's a way to expand the list of snap point options, but hours of searching haven't been fruitful.
    Actually, I'd like the see the large menu available in AutoCAD.
    How do you snap to points in Inventor?
  6. #6
    Senior Member
    Bishop's Computer Details
    Windows 7 Enterprise
    Dell Precision T1600
    Xeon E3-1280
    16 GB
    Quadro 600 1024 MB
    Seagate 250GB - ST3250312AS
    Western Digital 1024 GB - External
    2x Dell P2211H @ 1920 x 1080
    Multi-disciplinary
    Bishop's Discipline Details
    CAD Design, Manufacturing
    Multi-disciplinary
    Inventor 2013
    Nov 2009
    People's Republic of California
    321
    Snapping to points is pretty much automatic. Like JD said, you shouldn't have to mess with it. Whether you're in the drawing environment or the sketch environment, snap to endpoint should be a default behavior of Inventor. Make sure you're not pressing CTRL when you click, and move your mouse around a little bit to make sure you get the green dot.
  7. #7
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,905
    Then you are in a command if that is the screen you see. You need to be in the sketch environment but not in a command to get the Constraint Options dialog box that I was referring to.
    You will use geometry constraints - not osnaps. Geometry constraints are persistent tangent remains tangent as you move geometry. The constraint you are looking for, coincident between two points remain coincident as you move geometry - more powerful than endpoint osnap.
    The "large menu available in AutoCAD" should be top center of your screen labled Constraints.
    What version of Inventor are you using? Are you really using Inventor or are you using that "product" called Inventor Fusion that should have never seen the light of day? If you are in the line command for example and you move close to another line endpoint you should see a green dot indicating a constraint will be applied.
    Start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    and then go through the Help>Learing Tools>Tutorials
  8. #8
    Full Member
    Inventor 2013
    Aug 2012
    32
    When in sketch mode right click and click on autoproject that should get that green dot he is talking about and will snap to enpoints. Did this answer you question?
  1. Osnap bug?
    By specialforces27 in forum AutoCAD General
    Last Post: 31st Jul 2008, 07:04 pm
  2. 3D settings vs. classic settings
    By kmapro in forum AutoCAD Drawing Management & Output
    Last Post: 6th Aug 2007, 03:14 pm
  3. Temporarily override OSNAP, ORTHO, and other drafting settings
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 27th Feb 2007, 12:20 am
  4. Keep OSnap settings between drawings
    By Panther in the Den in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jun 2006, 04:40 pm
  5. Restoring osnap settings
    By xoom2 in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jun 2004, 08:47 pm
