cursedeye Posted July 31, 2012 Share Posted July 31, 2012 My file has over 100 layers and 20,000 containers that are in 3D. It worked fine when I drew them. After I closed the file, it always takes 5 to 10 min to open. I can't delete a layer (layer2) or rotate angle of view or any normal command such as purge and audit.., it always crashes. I was wondering that if I did anything wrong casued this, and that whether my approach of drawing these is correct, performace wise.. and what would be the better way of doing this..because my drawing is now uesless I can't even rotate it in vp or do anything... Thanks in advance. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 31, 2012 Share Posted July 31, 2012 .... 20,000 containers that are in 3D. All the same? One xref 20,000 times? Who can see and count the individual containers? Sounds like a situation that calls for a cosmetic texture material representation (picture applied to one solid - looks like the real thing). Quote Link to comment Share on other sites More sharing options...
cursedeye Posted July 31, 2012 Author Share Posted July 31, 2012 not all the same, but almost... you can find it here http://www.mediafire.com/?5s2ii1668zllbr4 Thanks Quote Link to comment Share on other sites More sharing options...
