Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 59
    Senior Member netman's Avatar
    Environmental
    netman's Discipline Details
    Professional Net maker
    Environmental
    I design and fabricate high end research and sampling gears for fishery scientists.
    AutoCAD LT 2012
    Feb 2012
    140
    Default Still have trouble with loading hatches in AC2012LT
    Ok.
    I found acadltiso and acadlt
    1. Copied the script ( numericals and commas and such)
    2. pasted them at the very end of both of these , one at a time
    3. saved to documents
    4. closed
    5. opened Program, no hatches.
    6. went back to acadltiso and acadlt....no script from the new hatches, just the ones that came with the program.
    I know i am doing something wrong... any suggestions?
    " The absolute, most expensive gear you will ever own is the one that does NOT WORK!"
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    Are you drawing using imperial or metric units?
    Is AutoCAD 2012 a 32-bit or 64-bit version?
    Environmental
    Environmental
    AutoCAD LT 2012
    Feb 2012
    140
    2012 lt 64 bit
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    What is the "path" to the your PAT files?
    What units do you use when drawing? Metric or Imperial?
  5. #5
    Environmental
    Environmental
    AutoCAD LT 2012
    Feb 2012
    140
    Imperial.
    ..... I am thoroughly out of my element. I had no idea i was editing anything. I was thinking a PAT file would just be a stand alone file. My error entirely.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    As I told you twice before, you do not have to edit either of the AutoCAD PAT files to use the hatch patterns you downloaded.
    What is the "path" to acadlt.pat?
  7. #7
    Environmental
    Environmental
    AutoCAD LT 2012
    Feb 2012
    140
    I have no idea what PATH. I use imperial for units.
    I appreciate your patience but I am just not that savy about this. My ignorance in this is the stumbling block.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    The "path" is the location of the acadlt.pat file. In a 64-bit system, using 64-bit AutoCAD, the path would look something like this:
    "C:\\Users\\YourComputerNameHere\\appdata\\roaming \\autodesk\\autocad 2011\\r18.1\\enu\\support\\acad.pat"
    To find the path to the correct file type the following at the command line then press Enter.
    (findfile"acadlt.pat")
    Note that acadlt.pat is the hatch pattern definition file used when a drawing with imperial units.
  9. #9
    Environmental
    Environmental
    AutoCAD LT 2012
    Feb 2012
    140
    ...stupid question.... what command line in Internet Explorer or in the auto cad program?
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    Quote Originally Posted by netman View Post
    The "command line" is a reference to AutoCAD not to Internet Explorer.
    I was able to replicate what you are attempting to do on my Win7 64-bit system running AutoCAD 2011 (64-bit).
  1. Loading Eagle point Hatches into ACAD 2010
    By Rflow in forum AutoCAD General
    Last Post: 12th Jul 2011, 09:25 pm
  2. hatches
    By moduloid in forum AutoCAD Beginners' Area
    Last Post: 4th Jun 2010, 02:02 pm
  3. Hatches
    By DODGE in forum AutoCAD General
    Last Post: 5th Feb 2010, 10:27 pm
  4. acadiso.pat can't find file - loading new hatches
    By alec in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 13th Nov 2009, 04:44 pm
  5. Trouble Selecting Hatches
    By hellnback in forum AutoCAD General
    Last Post: 28th May 2008, 11:38 pm
