NotePad should NOT be grabbing the zip file unless you associated it with the particular file type. Perhaps you have misstated what file NotePad is actually grabbing?
hugha,
Thank you for your input. I can only deal with one route at a time. Remark has a lot of time expended with me and I will ride this route a little while longer. I am sure it is MY error in this mayhem.
You are correct though on one thing, NOTEPAD keeps grabbing the zip file.
Thank you and I will certainly try your method if I need to go another route.
" The absolute, most expensive gear you will ever own is the one that does NOT WORK!"
REMARK,
I will attempt this tonight. Thank you again for spending such a huge amount of time with me on this.
I'll take a stab at it tonight when I come in form the shop. I am sure it is something I am not doing exactly.
The screen shots are perfect.... you must have been a teacher at some point.
Thank you and I will run the route tonight and post a follow up.
Thank you again.
Another option.
Create a new folder in the root drive ( C:\ ).
Put your individual custom PAT files in this folder.
Open AutoCAD. Invoke the Options command (there are a couple of ways to do this) and click on the Files and Folder tab.
Add the path to your new folder to the Support File Search path. After doing so click on the Apply button. Close out the Options window.
Example:
Let's say you name this folder CustomHatch. The path would be C:\CustomHatch.
Now when you use the Hatch command AutoCAD will automatically look in this folder. You should see your new custom hatch patterns listed.
netman: Did you finally solve your problem or not?
Remark,
I am finally able to sit down at the computer and look at this again. Its Saturday evening 3:40 PM here in Louisiana.
My sincere thanks for bearing with me on this.
Here goes again.....
What is a root drive and wheer would it be located. On the COMPUTER or in AUTO CAD itself?
* there are 5 folders already there from the software. All of them start with C:/
- Opened AC LT 12
- Tools
- Options
- Support files Path
The first starts with USERs....the rest say Program files
5. I click on ADD
6. I can not paste anything there...no right click on the mouse ....nothing. I can not locate the hatch file by itself when i use BROWSE. I have to put the HTH 2337 (hatch file) INSIDE of a NEW folder and put that folder in Documents. I called that folder New hatch folder.
7. I can then find THAT folder and place that in the new ADD blank under Support Files PAth
8. Add> OK close
I clsoe out and exit AC
I restart....the new file is still in place BUt No hatches.
there are 4 hatches grouped in that zippered file.
PLAN 2:
I went to the Computer> AC Program files > Support Files
I pasted the HTH 2337 zippered hatch file directly in with all the other Ac files there and closed
PLAN 3
I did both, then I did each one separately
still nothing.
what Am i doing wrong??
I have found two files
- Acadltiso Hatch PAtterns definitions
- Acadlt Hatch pattern definitions
Until you have extracted the PAT files from the HTH2337.zip file absolutely nothing will happen.
The root file is normally drive "C:\". It refers to your hard drive not AutoCAD. I get the sense here that you are pretty much a stranger to the inner workings of a computer.
When adding a path to the Support Files Search Path most of us will actually type the path in especially if it is a short one like C:\CustomHatch. Longer ones can be copied from Windows Explorer and pasted in.
If you have found the correct location of the two files mentioned in the above post then you have the option of copying the extracted PAT files to the same folder. Again, I would advise against editing either file as I think you'll just run into more problems given your lack of experience.
You are correct. I am lacking in experience with the inner workings of a computer.
I can live with out the new hatches until i find out what went wrong.
I actually got the files , extracted, into the Acadltiso and acadlt ( PAT) files.
The file showed up in the CUSTOM HATCHES.... but when I clicked on it, a warning came up and said the fiels were corrupt.
I back tracked and deleted everything. I am sure it was user error and I did something to the extracted files....who knows.
I can live without the new hatches. I just saw those expanded metal hatches and they looked more realistic for "netting" than did the standard AC HAtch No. 137.
Thank you again.
