Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    2
    Default model/paper space
    I'm not new to autocad but it has been a few years since using it and I have what I think is a simple question.
    When I was working with autocad there was a command I could use that could send something from the layout space to the model space. It is not the export to model space function. With this command I could select and object to send to model space. It was all done from the command line.
    Anyone know what I am referring to?
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    I think it is changespace or cspace or something like that (been a while since I use AutoCAD).
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    AutoCAD 2010
    Aug 2012
    2
    That's it, thanks very much, that was driving me nuts!
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,008
    For that matter, the name of the command is CHSPACE.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  1. Acad 2010 - Text size changes in model space behave as if in paper space.
    By Trickinitup in forum AutoCAD Drawing Management & Output
    Last Post: 7th Sep 2011, 03:44 am
  2. 2011 AutoCAD - Setting my LTSCALE in Paper Space as the same it is in Model Space
    By Rage221677 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 23rd Dec 2010, 07:31 pm
  3. Lisp- Copy Txt Form Model Space 2 Paper Space
    By T704 in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jun 2010, 04:19 pm
  4. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  5. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
Tags for this Thread
