Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    Full Member
    turboCAD's Computer Details
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    Default convert object made with 3d lines into a solid
    Hello everybody and thank you for having made this site where people can share ideas and and help others improve their Autocad skills.
    I drew a 3d shape using 3dpoly and I want to convert that drawing,which is now only a 3d sketch, into a solid.I have attached a picture of the lines sketch
    sulita.jpg.
    Thank you!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    Are the 3dpolylines open or closed?
    Full Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    Strangely, it says they are NOT closed.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    Why not just create the object as a solid to begin with?
  5. #5
    Full Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    the creation process for this object went as follows: I drew the surrounding lines and a space was left between the lines; I have to fill that space perfectly with an object of dimensions that are not standard (the angles are odd, the dimensions of the lines are not round numbers), the base of the pyramid is a rhombus rather than a square...But most of all, I want to be able to create a 3d object out of a selection of lines that describe/outline/border that object.
    Precision is crucial, this is the bottom line.
  6. #6
    Full Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    it basically consists of two pyramids with a rhombus shaped base and different heights
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    Great explanation but I did not understand a word of it.
    If you have a closed 3dpolyline then you can convert it to a surface. Surfaces can be thickened. If you have enough surfaces to create a water-tight structure then that, in turn, can be converted to a solid (AutoCAD 2012 and higher) via the SURFSCULPT command. I just tested the method and it works. I am currently running 2012.
  8. #8
    Full Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    If I were to extrude all surfaces and keep their common points it may work.
    Is there a way to do that, extrude all surfaces and keep the volume that is common to all?
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    You don't extrude the surfaces you thicken them with the...THICKEN command.
  10. #10
    Full Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    have a little more patience with me,please, I don't know how to create a surface from 3dpolylines. I would be grateful it you explained how to do it.
    thank you, ReMark!
  1. To remove redundant lines from a 3D solid object
    By mvrcad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th May 2011, 12:22 am
  2. Any better way to convert multiple lines into one object.
    By XecessivHP in forum AutoCAD General
    Last Post: 10th Nov 2010, 04:04 pm
  3. plot objects w/ solid color hatch and not show object lines: how?
    By Sudan in forum AutoCAD Beginners' Area
    Last Post: 31st Jan 2009, 02:15 am
  4. Can this object be made of solid?
    By didko in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Nov 2008, 01:56 am
  5. Shading an object made from seperate lines, arcs, ect.
    By ChrisM in forum AutoCAD Beginners' Area
    Last Post: 20th Jan 2005, 08:38 am
