Code:
(command "-insert" "RK_112" "_S" 1 "11648,18562,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,18430,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,18562,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,18430,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,18562,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,18430,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,18562,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,18430,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,18278,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,18146,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,18278,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,18146,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,18278,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,18146,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,18278,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,18146,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17994,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17862,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17994,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17862,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17994,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17862,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17994,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17862,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17710,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17578,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17710,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17578,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17710,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17578,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17710,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17578,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17426,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17294,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17426,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17294,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17426,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17294,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17426,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17294,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17142,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17010,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17142,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,17010,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17142,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17010,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17142,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,17010,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16858,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16726,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16858,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16726,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16858,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16726,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16858,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16726,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16574,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16442,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16574,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16442,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16574,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16442,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16574,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16442,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16290,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16158,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16290,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16158,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16290,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16158,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16290,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16158,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16006,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15874,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,16006,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15874,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16006,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15874,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,16006,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15874,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15722,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15590,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15722,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15590,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15722,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15590,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15722,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15590,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15438,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15306,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15438,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15306,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15438,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15306,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15438,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15306,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15154,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15022,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15154,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,15022,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15154,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15022,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15154,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,15022,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14870,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14738,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14870,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14738,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14870,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14738,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14870,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14738,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14586,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14454,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14586,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14454,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14586,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14454,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14586,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14454,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14302,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14170,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14302,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14170,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14302,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14170,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14302,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14170,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14018,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13886,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,14018,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13886,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14018,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13886,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,14018,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13886,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13734,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13602,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13734,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13602,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13734,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13602,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13734,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13602,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13450,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13318,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13450,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13318,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13450,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13318,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13450,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13318,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13166,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13034,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13166,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,13034,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13166,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13034,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13166,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,13034,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12882,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12750,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12882,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12750,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12882,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12750,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12882,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12750,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12598,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12466,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12598,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12466,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12598,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12466,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12598,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12466,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12314,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12182,0" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12314,130" 90)
(command "-insert" "RK_112" "_S" 1 "11648,12182,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12314,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12182,0" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12314,130" 90)
(command "-insert" "RK_112" "_S" 1 "11314,12182,130" 90)
