HENRYH83 Posted August 1, 2012 Share Posted August 1, 2012 Hi, I hope somebody can help me. Exception in acvmtools.arx ARX command Unhandled Exception C00000005 (access violation reading 0x0144) at address 697FF5BFh I have been getting the above error when i try to save or load up a new drawing on AutoCAD 2012. I can run the program but then the error appears. I have checked with the Autodesk online forum under autocad 2011 & AutoCAD 2012, where it would appear that there is a conflict between my graphics card driver and the software. Anyone know if this would be the case? Noone on the Autodesk forum can offer me a solution so im stuck and have nowhere to go with this. I am using a Toshiba Satellite Pro C660-2F6 with Windows 7 Professional Bit. With 6GB Ram Can you advise if you can help with this error as it is seriously effecting my ability to do my job. Thanks again Henry Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 1, 2012 Share Posted August 1, 2012 What is your graphics card and what driver are you using? Quote Link to comment Share on other sites More sharing options...
HENRYH83 Posted August 1, 2012 Author Share Posted August 1, 2012 If Im honest i dont really know how to check it as im new to Windows 7 Any idea how i can check Thanks for replying. H Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 1, 2012 Share Posted August 1, 2012 In AutoCAD commandline type _3DCONFIG, then select "View Tune Log" button, should be in section 3D Device. Quote Link to comment Share on other sites More sharing options...
HENRYH83 Posted August 1, 2012 Author Share Posted August 1, 2012 Heres what it says: Performance Tuner Results Log Version: 18.2.0.0 Date of Last Tune: 11/07/2012 Machine Configuration --------------------- Processor Speed : 2.4 GHz RAM : 5939 MB 3D Device --------- Name : N/A Manufacturer : N/A Chip set : N/A Memory : N/A MB Driver : N/A Hardware acceleration is not available because not enough video memory is available. Current application driver: Software Current Effect Status: ---------------------- Enhanced 3D Performance: Not recommended and off Smooth display: Not available Gooch shader: Software emulation in use Per-pixel lighting: Not available Full-shadow display: Not available Texture compression: Not available Advanced material effects: Not available Available application drivers and effect support: ------------------------------------------------- Software driver Effect support: Enhanced 3D Performance: Not applicable Smooth display: Not applicable Gooch shader: Software emulation only Per-pixel lighting: Not applicable Full-shadow display: Not applicable Texture compression: Not applicable Advanced material effects: Not applicable Autodesk driver: Not Certified Effect support: Enhanced 3D Performance: Available Smooth display: Not available Gooch shader: Software emulation only Per-pixel lighting: Not available Full-shadow display: Not available Texture compression: Not available Advanced material effects: Not available Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 1, 2012 Share Posted August 1, 2012 See THIS article. Quote Link to comment Share on other sites More sharing options...
HENRYH83 Posted August 1, 2012 Author Share Posted August 1, 2012 Intel® HD Graphics Driver Provider: Intel Corporation Driver Date: 28/07/2010 Driver Version: 8.15.10.2189 Digital Signer: Microsoft Windows Hardware Compatibility Publisher Quote Link to comment Share on other sites More sharing options...
HENRYH83 Posted August 1, 2012 Author Share Posted August 1, 2012 This is my error message. Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 1, 2012 Share Posted August 1, 2012 Just how did you come to find out the error was generated by a conflict between your graphics card driver and AutoCAD? Are you current with all 2012 updates? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 2, 2012 Share Posted August 2, 2012 From Autodesk site........ These types of issue are commonly caused by using an unsupported video card or driver version. You will need to verify that the video card and/or driver is listed as certified per the links below. Try updating your driver HERE Quote Link to comment Share on other sites More sharing options...
HENRYH83 Posted August 2, 2012 Author Share Posted August 2, 2012 Just how did you come to find out the error was generated by a conflict between your graphics card driver and AutoCAD? Are you current with all 2012 updates? I was pretty much informed of this on the Autodesk forum. I dont know how to check if I current with my updates. Quote Link to comment Share on other sites More sharing options...
HENRYH83 Posted August 2, 2012 Author Share Posted August 2, 2012 From Autodesk site........ Try updating your driver HERE Thanks i'll try this later this evening. I did 'roll back' my driver last night and autocad worked fine, however the graphics on the laptop became really poor in comparison to what i was getting before. I have since restored my machine back to the settings i had before changing the driver settings. obviously this has made Autocad no longer work. I see there are 3 drivers listed on the 'link' does it matter which one i use? Thanks again for your help and sorry for being such a dumbass. H Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 2, 2012 Share Posted August 2, 2012 Look in the upper right hand corner of your screen. See that downward pointing arrow? Click on it. Then click on the "About" option. That will open a separate window. Your version of AutoCAD will be listed as well as any service pack (SP) information. See mine? I'm current with Service Pack 2. And you? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 2, 2012 Share Posted August 2, 2012 Thanks i'll try this later this evening. I did 'roll back' my driver last night and autocad worked fine, however the graphics on the laptop became really poor in comparison to what i was getting before. I have since restored my machine back to the settings i had before changing the driver settings. obviously this has made Autocad no longer work. I see there are 3 drivers listed on the 'link' does it matter which one i use? Thanks again for your help and sorry for being such a dumbass. H Try all 3 if necessary, but start with the one on top. I've never had luck with Intel graphics cards and AutoCAD, might want to check if a dedicated graphics card is available for your computer. Quote Link to comment Share on other sites More sharing options...
HENRYH83 Posted August 2, 2012 Author Share Posted August 2, 2012 Thanks again. Just trying the new drivers now. I take it all i need to do is just run the exe when it downloads, do i need do unload the old driver? Quote Link to comment Share on other sites More sharing options...
HENRYH83 Posted August 2, 2012 Author Share Posted August 2, 2012 I have now tried all 3 drivers by simply running the exe and keep getting the following error message Quote Link to comment Share on other sites More sharing options...
nijeesh4all Posted August 16, 2014 Share Posted August 16, 2014 is my log Version: 18.2.0.0 Date of Last Tune: 8/16/2014 Machine Configuration --------------------- Processor Speed : 2.4 GHz RAM : 1907 MB 3D Device --------- Name : N/A Manufacturer : N/A Chip set : N/A Memory : N/A MB Driver : N/A Hardware acceleration is not available because not enough video memory is available. Current application driver: Software Current Effect Status: ---------------------- Enhanced 3D Performance: Not recommended and off Smooth display: Not available Gooch shader: Software emulation in use Per-pixel lighting: Not available Full-shadow display: Not available Texture compression: Not available Advanced material effects: Not available Available application drivers and effect support: ------------------------------------------------- Software driver Effect support: Enhanced 3D Performance: Not applicable Smooth display: Not applicable Gooch shader: Software emulation only Per-pixel lighting: Not applicable Full-shadow display: Not applicable Texture compression: Not applicable Advanced material effects: Not applicable Autodesk driver: Not Certified Effect support: Enhanced 3D Performance: Available Smooth display: Not available Gooch shader: Software emulation only Per-pixel lighting: Not available Full-shadow display: Not available Texture compression: Not available Advanced material effects: Not available Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 16, 2014 Share Posted August 16, 2014 is my log Version: 18.2.0.0 Date of Last Tune: 8/16/2014 Machine Configuration --------------------- Processor Speed : 2.4 GHz RAM : 1907 MB 3D Device --------- Name : N/A Manufacturer : N/A Chip set : N/A Memory : N/A MB Driver : N/A Hardware acceleration is not available because not enough video memory is available. Current application driver: Software Current Effect Status: ---------------------- Enhanced 3D Performance: Not recommended and off Smooth display: Not available Gooch shader: Software emulation in use Per-pixel lighting: Not available Full-shadow display: Not available Texture compression: Not available Advanced material effects: Not available Available application drivers and effect support: ------------------------------------------------- Software driver Effect support: Enhanced 3D Performance: Not applicable Smooth display: Not applicable Gooch shader: Software emulation only Per-pixel lighting: Not applicable Full-shadow display: Not applicable Texture compression: Not applicable Advanced material effects: Not applicable Autodesk driver: Not Certified Effect support: Enhanced 3D Performance: Available Smooth display: Not available Gooch shader: Software emulation only Per-pixel lighting: Not available Full-shadow display: Not available Texture compression: Not available Advanced material effects: Not available Your system is not adequate to run full AutoCad 2012, according to that log. 2 gigs RAM? not even close to enough. It didn't even list the video card memory size other than to say there is not enough. Quote Link to comment Share on other sites More sharing options...
