Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2013
    Aug 2012
    7
    Default Comparing Solidworks with Inventor+Alias
    Hi Guys,
    New member here - although I must confess to reading posts on this board for quite a while now. Thanks for all the helpful comments.
    It's a question that comes up from time to time. Rather than asking a general question, I wanted to ask in form of a list.
    1. Someone commented a couple years ago (I think... it may have been more recent) that he observed more students signing up to learn Solidworks than Inventor and that it was the first time this has occurred. Has this trend continued? Do you see Solidworks gaining more popularity?
    2. Relates to question 1. Has Autodesk done anything to counter this trend in terms of pricing? I have asked around and found out Inventor sells for 3,300 (Not Inventor LT or professional). Posts from a couple years ago mentioned of that Inventor ranges 4,000-5,000. It seems to me that Inventor prices has come down.
    3. For someone in product design that is in the computer peripheral industry - designing products like ergonomic computer mice (quite of bit of curves) and keyboards, which product do you recommend getting? Obviously this person is me and I plan on also getting Alias if I get Inventor. I've asked around and the combined cost of Inventor (regular) and Alias (design) is around 7,000, which I think is pretty comparable with Solidworks. Please correct me if I'm wrong and if Solidworks sells for less. I figured the Inventor+Alias combo is cheaper that getting the inventor premium suite.
    4. Which product is better for patent drawings? As some of you may already know, USPTO only accepts drawings with black and white colors only. The color grey or prints made in greyscale is forbidden. They do not allow any shades done in grey. If shades are included they must be in forms of black lines. Do either program provide a way to include shades made with black lines?
    Thanks in advance!
    Forum Newbie
    AutoCAD 2013
    Aug 2012
    7
    Sorry I guys, I meant Inventor Ultimate Suite. I don't think the premium suite includes Alias.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    This is simple math.
    Inventor = SolidWorks.
    I think you can figure out the Inventor + Alias equation. Not even comparable.
    Inventor does have an Illustration render type that somewhat resembles typical patent drawings and can be set solid black lines on white background. I think you might still need to turn these over to an experienced patent artist for final work - but as the Inventor output is very close it would reduce billable hours to get the final art.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    AutoCAD 2013
    Aug 2012
    7
    I see. Thanks.
  1. Alias for Inventor
    By dshowalt in forum Autodesk Inventor
    Last Post: 2nd Sep 2010, 10:14 pm
  2. Solidworks to Inventor?
    By farrous13 in forum Autodesk Inventor
    Last Post: 15th Jun 2010, 07:13 pm
  3. How much do I need to run Alias for Inventor
    By IronHorse in forum Autodesk Inventor
    Last Post: 11th May 2010, 12:35 pm
  4. Alias design for Inventor 2011
    Last Post: 9th May 2010, 12:20 pm
  5. solidworks v inventor
    By FIFTHTEXAS in forum Autodesk Inventor
    Last Post: 1st Sep 2006, 05:16 pm
Tags for this Thread
