@Bill Tillman: I just created that from Lee's code in order to allow you to see the error that is issued; I didn't had in mind any kind of optimization. Please don't ignore that Lee paid attention to other elements - clean behavior and memory garbage clean-up.
For sure my excerpt it will not compare in terms of simplicity and effectiveness with the equivalent line below (presuming you have Lee's routine loaded at start-up from a utility library):
Code:(LM:Popup "X" "TEST" 2)
Regards,
Mircea
AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
Tell's me your WSH is not setup correctly. There might have been an issue while installing which didn't register your scripting host as a COM server.
Perhaps try re-installing it from here: http://support.microsoft.com/kb/188135
Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
