Results 1 to 8 of 8
    Full Member
    KoTa04's Computer Details
    Windows XP
    Construction
    KoTa04's Discipline Details
    Construction
    BSc. Civil and Mechanical Engineering
    AutoCAD LT 2011
    Jun 2012
    Chatham, Ontario
    27
    Default hatching around dimensions and other objects
    Hello all,
    I have this issue where I have stone right below some framing and other objects. I use a hatch to fill in the square of stone. When I use the hatch, I send it to the back of the drawing order, but it is right below a bunch of my dimensions. These dimensions become hard to see. I could have sworn that I once saw my hatches leave some extra room around the dimensions. Is there a way to make them easier to see? I guess the ugly solution I have right now is to put small boxes around anything within the hatch to leave some room.
    Thanks,
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Either through properties or DimStyles set Text Fill Color to Background.
    Full Member
    Windows XP
    Construction
    Construction
    AutoCAD LT 2011
    Jun 2012
    Chatham, Ontario
    27
    Genius! Thank you very much!
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    You are welcome!!
  5. #5
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, Vista and XP Pro
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    866
    You can also select the dimensions when selecting the object with the island mode set to outer, or when selecting the point.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
  6. #6
    Full Member
    Windows XP
    Construction
    Construction
    AutoCAD LT 2011
    Jun 2012
    Chatham, Ontario
    27
    I'm unable to "publish" my layouts to a pdf when setting my rotated dimensions text fill colour "background", I get the error message: "Your request could not be completed due to an unexpected problem. Turn off background plotting and try to plot again." Is this common? Is there a work-around?
  7. #7
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    Did you turn off background plotting?
  8. #8
    Full Member
    Windows XP
    Construction
    Construction
    AutoCAD LT 2011
    Jun 2012
    Chatham, Ontario
    27
    I didn't, it works now. Thank you.
    Exactly what is background plotting? and what happens when I uncheck it?
  1. Dimensions on 3d objects
    By t-time in forum AutoCAD Beginners' Area
    Last Post: 5th Dec 2011, 12:45 pm
  2. QUICK Objects dimensions
    By rocneasta in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Sep 2011, 11:34 am
  3. Problem with hatching overlapping objects
    By Mr.Alex in forum AutoCAD Beginners' Area
    Last Post: 3rd Aug 2011, 01:51 pm
  4. Setting dimensions for objects
    By dannyboi in forum AutoCAD Beginners' Area
    Last Post: 17th Dec 2009, 02:30 am
  5. Dimensions on 3D objects
    By CadMax in forum AutoCAD General
    Last Post: 24th Jun 2008, 09:58 am
